First off, thanks to all that have answered questions here and helped me on my journey to make this happen.
I have been trying for several months to get my Excursion ready for self recovery. I installed Buckstop bumpers front and rear, with a Warn 16.5ti winch. I have now gotten most of the recovery gear together and into the vehicle.
I did not want to use the steel winchline, and I decided to make my own.
Here is my completed winchline. 90 feet long, made of 7/16" Amsteel blue, splices are secured with 1/8" braided nylon/poly twine. Blueline gusseted thimbles that I painted in my favorite color. 10 foot sliding abrasion guard, and a 10 foot red warning sleeve. Started with a grade 100 clevis self locking hook, and ended with a custom termination method.
The end of most synthetic winchlines are normally terminated with a crimped on battery ring terminal, just like the wire ropes. I don't think it works very well.
The Line, Amsteel blue, is slippery, and does not crimp well. I tried it, and it did not hold more than 30 to 40lbs. I tried different glues, crimping them while still not set. The amount of holding power was still pretty low, with the best at around 70 lbs. I tried 6 different popular methods.
I thought about it for a long time and left a part of the brain to work on it. Well, after about 4 or 5 tries, I found a method that will hold more than my weight hanging on it and bouncing around. I took a peice of one inch tube webbing, cut a hole for a grommet, flamed and used thick superglue on the edges, and installed the grommet while the glue was still wet. The stuff I used, from model airplane building, gave me about 30 to 40 seconds to set the grommet.
Next draw a box and X with a pen on each side of the webing for a sewing guide. Insert the taped bitter end of the line into the webbing. Next, I used a Sewing Awl and thread from Harbor freight to sew through the web and line along the box and X. I sewed a smaller box toward the end. The results are Below:
I used 2 inch tube webbing from Northern Mountain sports to make the 10 foot abrasion guard. I cut the peice to length, and flamed and dipped each end in plasti-dip twice to seal the ends. It slides along the rope very well and will go all the way to the thimble with ease to protect the line from UV during storage on the winch.
The Winch end of the line needed something to identify when it would be getting close to the end of what you can pull out. I used Red one inch tube webbing, sealed the ends, and slid it on the line. Not a tight fit, and it can be moved along the line, but not real easily. It has to be put far enough out to stay off the first 10 wraps or so on the drum.
The hook end. The hook and link are grade 100. Way stronger than the line.
Installation of the winchline end and the line fully installed:
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229097&.jpg)
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229070&.jpg)
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229071&.jpg)
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229072&.jpg)
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229073&.jpg)
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229075&.jpg)
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229074&.jpg)
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229098&.jpg)
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229100&.jpg)
![sizeimage.php](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=229099&.jpg)
