89 FJ62 Toolkit
MoGas
Central Scrutinizer
I will have to look at mine to be certain but, I believe our 62 has:
Screwdriver with reversible shaft. Phillips on one end slot on the other.
2 open end wrenches, I think one is 8/10mm and the other is 12/14mm
Slip joint pliers
Spark plug wrench
Hub cap pry bar
Hub cap installation tool
Jack crank handle and 2 pieces to make up the jack/tire lowering tool
Lug wrench
I have also added an adjustable spanner from a 40 series.
Dave
MoGas
Central Scrutinizer
Thanks Dave, that sounds complete.
I am still unsure about the adjustable spanner.
It's just a crescent wrench made by Toyota. They stopped putting them in the tool kits in the early 1980's. I found one at a garage sale.
Dave
BiG BoB
My 83 HJ60 has the "Toyota" adjustable spanner along with the complete kit. Also has a circa 1983 "Toyota" bulb and fuse kit in the glove box that's been topped up as needed.
Sean
gotmud
IIRC, the bags are still available as well. Let me know if you are interested in ordering one and I'll double check the availibility.
Breezy78
