FROADER's 2005 F-150 Crew FX4
FROADER
Can you remove the crossbars to maintain access to the bed?
'Unfortunately,' no. I had thought about doing that, but I will be setting up a pulley system in the garage to store it when I don't want it on the truck. It's only held on by the 8 bolts in the angle iron on the bed rails, so it won't really be a big deal to remove it.
I had the tonneau cover on the truck (since purchased), so I was used to owning a nonfunctional truck... :) If I needed to use a truck bed, I swapped with a friend, which I can still do.
cocco78
Very nice, to bad you couldn't keep the bed covered to keep your stuff clean and dry...
If you want to make the cross bars removable...
http://www.ballisticfabrication.com/ID-Tube-Clamp_p_1467.html
FROADER
I may still try and find a roll-up cover that will work with the rack.
We thought about using those tube connectors, but I'm not worried about it. I'm going to do the pulley system in the garage.
^^are those the ones they used on Extreme 4x4 on the s10 truggy?
Yeah, those are them.
FROADER
It's getting closer to looking like my photoshop idea...
I painted the wheels on Tuesday afternoon.
Wolvee
Outstanding rack you've made.
I'd like to do something like this on my 01 SCREW. I'm putting on a hard tonneau cover on Monday and I'm going to start mocking up some Carbon Fiber tubing to make a large rack similar to yours to go on top. (I'm not putting a Tent on top of the rack but it will carry gear.) I've never worked with the Carbon tubing before but it looks to have amazing strength for the weight.
http://www.rockwestcomposites.com/browse/round-carbon-fiber-tubing
Houie
