jeepdreamer
Rear diff...
Try Ruff Stuff...they make some diff covers that would be right at home on an MRAP!:drool:
I replaced my stock ATF+4 tranny fluid w/Amsoil Universal ATF with good results. It has slightly better cold weather shifting characteristics than the stock ATF. Tranny holds 6.2 qts and the transfercase 3 qts I believe. The Amsoil site has all the capacities. I've ridden in a 2.0 Carli system. It'll work out fine for you. The trackbar they provide is far better than the stocker.
I have an '06 Dodge CTD with the 11.5" AAM. Put on a "Rockcrusher" rear diff cover. It is seriously stout and it provides for a few extra bottles of gear oil. I just noticed that the ICON Toyota that is for sale in the Expo classifieds has a "Rockcrusher" for its rear diff protection. They definitely appear to be VERY tough and UnCrushable ductile iron!
Fit is excellent with no leakage problems after installation. As a side note.. the fill hole is quite high on the cover. So much so that I believe you would over fill the diff if you used the hole as a reference. The oil level should sit between the bottom of the axle tube and the bottom of the axle. Consequently I ended up with 7.0 qts... a bit of an increase over stock. Just FYI should you go this route.
Stopping by to say hey and I will be following your build looking forward to seeing your new camper top flippac.. Let me know so I can order one.
