Using 12 Volt's for Apple laptop and iPad
Kilroy
Anyone using a device to run their MBP or iPad off 12 volts without using an inverter?
I found a link to the Lind site. But there listing is for antique Apple products (ibook, G4).
I also found this site for a product which looks like a 12 volt to 19 volt converter. http://mikegyver.com/Store/
Wondering if anyone using these products or other to get away for the waste of using an inverter.
dwh
Tail-End Charlie
My Acer netbook came with a 30w AC charger, so I bought a 30w DC charger to use in my camper. In Linux, acpi reports that my netbook uses 9w in power save and 14w when charging the battery, so I figured a 30w power supply would be fine.
After the second one overheated and burnt out I decided to get something beefier. I got one of these for 18 bucks off eBay:
http://sangertek.en.made-in-china.c...Gateway-Car-Charger-19v-4-74a-YD190-474-.html
LOVE IT. It has a nice thick cable and it never even gets warm. They make it with a lot of different tips, but if unsure it's probably best to get a unit with interchangeable tips.
Kilroy
I've got a small inverter like the Kensington already and use it in the car while moving. But to use with a 12 volt source such as a car that is not running, will really pull down the battery quickly.
The Acer should be able to charge right off a running car if it uses 14 volts, since that is what an alternator is putting out. Apple stuff needs 19 volts.
dwh
Tail-End Charlie
My Acer ZA3 (0751h) takes 19v. I also have a 7200mAh 9-cell battery for it, so it goes a good 8 hours before it needs a recharge (unless I use my 1w Alfa wifi card, then it only goes about 6 hours).
But even if it used 14v, I'd still use a power adapter. The one I have takes 10v-15v on the input and puts out a nice steady 19v. I like regulated power for my tronics.
haven
The iPad and MacBook have very different power requirements. There are plenty of 12V chargers for the iPad available from third parties.
The MacBook has a higher voltage requirement and that funky MagSafe power plug. HyperMac used to make a 12V power adapter for the MacBook, but Apple made them take it off the market because of licensing issues with the Apple's patented MagSafe connector.
Here's the HyperMac page
http://www.hypershop.com/HyperMac-Pure-DC-Car-Charger-for-MacBook-p/mbp-car.htm
I could find only one retailer still selling the HyperMac 12V charger online
http://www.simplyelectronics.net/mainproduct.php?currency=usd&pid=10810
Maybe HyperMac will properly license the MagSafe plug, and return to the market in the future.
Dillon
dome light
You can walk right into the Apple store and pick up a MagSafe Airline Adapter for $49.00. It has an em_power plug and a 20mm plug. Or you can use the Kensington version for a few bucks less. That will power your MBP. Belkin and Griffin both make auto charger plugs that use a USB connector to power/charge iPads, iPods, and iPhones.
dwh
Tail-End Charlie
Do you more details/description/link from Ebay for this item?
Um...no?
I would say the details/description at the link I posted are...well...detailed.
As for the eBay link...it's been a while since I bought it. I'd have to check but well over 6 months. The vendor I got mine from was www.sibusa.com which redirects to www.sibstore.com which doesn't seem to list it now.
If you just do a Google search for that part number you'll find a whole bunch of vendors selling that unit with various tips for various computers:
http://www.google.com/search?q=YD190-474&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official
