Yeti and the Marshmallow
TroySmith80
In my line of work (automotive interior reconditioning www.oregoncolorglo.com) we have a product that is designed specifically to remove silicone. It works very well. It is not available at retail though. I'd imagine you can probably find a similar product at an auto parts store though, maybe...
Otherwise, just wipe off the thickest parts with DRY rags, and let time do the rest.
Chazz Layne
Administrator
You know that slime that comes on used/new cars? I hate it. I can't figure out how to clean it out of the van. I tried soap and water, Windex, some other glass cleaner, it won't come off. :/ I guess I'll try again when I remove the bulkhead and rip out the nasty rubber mat, because the rear of the van needs a serious scrubbing any who, under that rubber mat...
'The horror....the horror....the horror."
I hate that stuff with a passion. I've had good luck removing it with this in the past...
It has almost magical abilities in automotive use. :)
Silverado
I'd start searching for U-Pull Junkyards in your area, good for hours of fun and cheap parts. I know there are a bunch of them in California
I have better results using dawn as a handcleaner......runs circles around any stuff I can buy at the parts store and it's cheap when you buy a big bottle at costco.
Basement Yeti
Bored of searching, I'm just going to get a cheap generic one and screw it into one of the ribs in the roof the cab if it doesn't fit.:coffee:
Basement Yeti
Alrighty now. I've got some tools, a gps, a backup camera system, and some miscellaneous odds and ends ordered. I just need a decent used power drill from Craigslist and that should take care of most of my tool needs.
I have some serious thinking to do about my jack and winching options. I kind of really want to go with an all cast hi-lift jack. I don't really foresee myself getting an electric winch and for the few cases I need to winch myself out I think I might just get a hand winch. For now I could use my tires to lift the van, but at a later date I will be adding recovery points which I could use, I think.
As for my bumpers I don't know if I can justify custom metal off road bumpers because I just don't see the need.
Hm.
MrBeast
Also check out the pawn shops for tools, you can some times score some killer deals there.:wings:
Basement Yeti
Though I now adventure in Casa Azul & Mayahual, I previously did my adventuring in 3 Ford E250 van over about a 20 year period...So I have a little experience about modifing vans. I have a little advice for you...
Yeti, SLOW DOWN!!!!
I know you are excited, I would be too if I were to be undertaking your personal adventure! But, from experience I have found that charting too far in advance in a development project is an excellent way to end up with a project that dose not ultimatley suit your needs.
Why? Because you do not really know what your needs are! Sure you have read everything that people on Expo and other sites have to offer, probably 3 time...But they are not you, and the way they use their adventue vehicle is not the way you will probably use yours.
So with that out of the way. How about taking care of a couple of simple items, then go on a road trip for a couple of days. I keep a small ring binder notebook in each of my adventure vehicles that I record my fuel fills, notes on locations, and most importantly...Future modifications I want to make to my Rig. I have owned Casa Azul for 16 years and after every trip i have 3 or 4 pages of things i want to change or build. my point is that your relationship with your adventure vehicle is dynamic and will be constantly changing until the day you sell it and buy another one!
These are the first things that I would do...
* LEAVE the silcone goop alone! It is a protective coating and though it may look icky it serves a purpose, keeping your vehicle from rotting apart.
* Keep your headliner. It reduces noise, winter cold and summer heat. You might want to go to a detailer that has fabric "dry cleaning" equipment and have it and the seats done. Also, where paneling the walls in a van is easy...fabing a new headliner is a total PITA!
* Keep your rubber floor liner! Sure, pull it out and have it pressure washed. but then put it back in...Then get a nice throw rug for the back that can be pulled out and shaken out & vacuumed. The more off road adventuring you do, the less you will be wanting secured carpet. The more you make your rig so that it can be "hosed out" the better.
* Do not undercoat your van, It is not necessary and could potentally hide issues like body rot and cracking. Have it really well steam cleaned before your first road trip, then spend time under your van after the road trip to see what is leaking.
* Go to a marine fabric shop and have them make you a REALLY good set of "black out" curtins.
* I would be VERY careful about doing a fuel shut off. In some "systems" it can cause problems. I would go to an automotive security specialist and see what systems the have for disenabling the ECU correctly.
* Go to a fabricator and have a lock box / vault welded into your van in a discrete / non visable location. make sure it is big enough to take a laptop, cameras, documents, etc. .
* I personally would bail on the heated mirrors, back up camera, central locking system...Again the more you explore "deep" the less you want you be dependent on electronics. The only electronic device in Casa Azul is the stereo.
* Plan on setting up a dual battery system ASAP. Forgive me, i'm not trying to diss you here, but it is one of the first "green-horn" mistakes...camping in some cool remote place, listening to the stereo late into the night...And not be able to strart the van the next morning due to a dead battery.
* Also, disable the switches that turn on the overhead light when you open the doors!
* Forget about the dents and scratches! In this crowd..."Desert pin-striping" is considered vehicle up-grade! If your use your van "correctly", you'll be collecting more than what is already there. You might want to do a Line-X wainscoat.
* I agree with Mr.Beast, don't worry about the wheel locks! If anybody is going to steal anything it will be the whole van.
I hope my advice is helpfull. Good luck!
Thanks, but those sound a lot like your needs. Most of the ideas I've set forth are just that, ideas. And I never do anything without research or a good reason.
The backup camera is a matter of safety. I'd rather see some little kid dash out behind my van before I run them over.
The entire van is getting insulated. I'd rather deal with putting the headliner back in than cooking alive or being cold.
The rubber mat is wrinkled, warped, and most likely out gasses tons of VOC. It's getting taken out so I can insulate and floor behind the bulkhead. The front mat is staying to protect from muddy shoes and stuff.
The house battery bank will be completely separate from the van battery, for now wired to the alternator with an isolator and shunt. At some point and time when I can afford it I'll add a solar panel and/or a generator. And yes, I know I need an inverter, fuses, breakers, and a battery charger etc.
I think I'll have a small 12V fridge, a few LED lights, a fan, and a few electronics to charge just starting off. I've decided to scale back my plans and will be holding off on a bunch of stuff and just going with a hand pump sink and stuff like that.
Thanks for the steam cleaning tip. But I think you assume I will be doing more with this van than I actually am.
Btw I was just out there looking at Marshmallow and I realized I dislike that front bumper, a lot. Must...fix...ugly..bumper.
Basement Yeti
Yeah, I am pretty sure the one I got will fit.
I was just outside doing some cleaning and measuring. The van sure seems smaller than in pictures and in measurements, but I am not at all dissatisfied with my purchase and I like the compact nature of it.
I found the back up siren so that will be easy to yank out once I get my rear view camera.
I have a pretty good idea of what I need to do, I just need to wait for some paperwork and parts to come in before I can get rolling again.
Hey, someone mentioned Firestone has a lifelong alignment guarantee, are Firestones good tires? It has 215/70R/16 Firestones on right now.
MrBeast
Firestones are garbage, get either Bf Goodrich, Michelin or Goodyear, and try to find tires that are made in the US, they will be better quality.
Basement Yeti
Duly noted. I will steer clear of Firestone.
Trying to figure out if these are 12V sockets...
Uploaded with ImageShack.us
Annoying back up siren under rear bumper. I wanted to rip it off there so bad...
Torn tab on my fuel door. An easy fix I am told.
My broken rear door hatch. I can reach in and pull on the rod and it unclips, but the doors don't free themselves from each other.
Luckily the fuel door, passenger side mirror, and rear door mechanism will be covered by the dealer who sold it to me.
Just waiting on parts, then things will get more interesting.
