winkosmosis
I found an interesting article about oil viscosity
http://www.machinerylubrication.com/Read/518/motor-oils
Mmm this make me think. My owner manual, the label on the oil cap on the engine both says to run 15W40. (wich is actually what i have, and what the dealer put in the last check they did at 10000Km) This can be due to the different weather we have here in mexico?
Is it wrong to use synthetic 10W-40 all over the year with 70-85 F in the summer and 20-40 F in the winter?
The Jeep dealers over here use only mineral 15W-40 for the whole year and I thought that synthetic 10W-40 would be better.
IMO it should be ok..
I got some Chevron Supreme 10W-40. But I'm scared to veer from Chrysler's recommendation. I really wish some Australian would confirm that 40 really is OK
I own a 1997 ZG Grand Cherokee Limited ( a ZG is an export build RHD ZJ built by Jeep's erstwhile partner Daimler Benz owned Steyr miltary plant in Graz, Austria.
I spend a lot of my time in Australia....the last 1 1/2 years in far north Queensland (FNQ) from Cairns to about 350-500 miles north, now I've driven 1/2 way across northern Australia and am around Darwin.
Here in Australia, the Owners Handbook specifies 15W as the MIN for minimum temps of about 0 degrees Celsius/32 deg Fahrenheit and suggests 30 or 40 as the upper value...... most 4.0L Jeep owners, dealers and Jeep specialists seem to use 20W/50 petroleum based oil because it's so common here......I've paid attention to Jeeps admonition and use a Shell Semi-Synthetic 15W/50 for High Mileage Engines (it's a heavier version of the same in a 10W/30, 10W/40, 15W/40 versions).
I've got nothing but praise for it (the oil.....and the Jeep 4.0L engine)....a few weeks ago the car ticked over the 240,000 kilometre point - that's about 150-160,000 miles.
I use a semi-synthetic because after the initial oil drain when new I put in Mobil 1 it leaked from every possible orifice!...The Dealer said that Jeep oil seals and gaskets just aren't meant for synthetic oils!....BTW I've used Mobil 1 in 1996 and 2003 Range Rovers witout any problems.
BTW.......That 15W/50 oil that I use is Shell Helix Synthetic Technology Oil for High Mileage Vehicles.....it comes in metallic dark blue plastic bottles, and because I use the larger/longer oil filter (#3001 or Z9 etc) I fill up with EXACTLY 6 litres (instead of 5.7) due to the bigger filter. I use Bosch premium oil filters with the anti-drainback valves.
