shortbus4x4
Go for it.
I'd rock the portals.. I've 1/2 thought about running a set on my Hemi/M725.. but the roof height after it gets campered will be bad enough with 37s and normal axles. Adding portals with its already 'lcg' axle position would be nuts.
Any thoughts on how you're going to make the nearly centered mog diff clear the pretty darn tall 6bt and keep the axle in the same spot? Seems like you'll be running around 53s to get everything clearing right.
