my1stcummins
That's a great tire and wheel look. I need to get some black rims on my white beast.
This is my first post. Just thought I would introduce myself. I've searched around here a bit as a visitor and finally purchased a vehicle I deem worthy of expedition travel. A 1998 GMC K1500 6.5L Diesel. Although these engine have had there issues with a few simple upgrades they can be great, long lasting and simple to maintain/work on. Its going to be a slow build, like everyone else, but it should be a lot of fun. Im starting with addressing the reliability of the engine and fixing up the little details of the truck then a full on build.
Short term plans include:
Larger diameter exhaust and downpipe
PMD relocation
New Injectors
Leveling Kit with Bilsteins
Tires and Wheels
Long term plans:
Solid axle swap with dana 44's front and rear
Front winch bumper
Rear bumper
Sliders
Bed cage and rtt
Ill try to post details and pictures along the way. Im really excited about starting this truck. The goal is to keep fuel mileage as high as possible and total height to a minimum. Even with the sas I would only like to fit 33's and I am willing to trim. Please feel free to comment or give suggestions. I would love the input.
-Tyler
A SAS conversion is not needed if you do that way it should be a hi-pinion ford frt diff d/s drop. However, you would be better served by going to the 1 ton IFS diff found in the K2500 and K3500.
Running 50psi to meet oem specs will batter suspension suggest poly susp bushings.
Cranking front torsen bar to lift is a bad idea, some aftermarket suspension manuf have a frt/ifs diff drop option.
As for 33.3" 255/85/16e on stock wheel would fit just right w/o mods and not stress anything suspension/bearing wise. Tire dia or gearset change requires vssb to be hacked to maintain speedo/trans shift calibration.
32.7" 285/75/16e will work on stock type rim of proper width and bs but bumper and rear of fenderwell my need some trimming.
35" will fit with cutout Bushwacker flairs, no lift needed, but offset and rim width would
stress your 1/2 sealed hub bearings and suspension for sure.
What transmission and gear ratios you have?
The Dana 44 axle will get you better fuel economy compared to the 14 bolt. The Dana 44 can be built almost as strong as a Dana 60. I will be putting Dana 44s on my wifes Suburban (as soon as I find one with barn doors and a 6.2 diesel).
the rear dana 44 is going to be much skinnier than your stock 10 bolt rear. and you wont be gaining any strength.
do a ford hi pinion 44 front out of f250 so you get leaf spring mounts
and a ff or sf 14
i would do a ff 14 with a shave and a diff cover and call it a day.
KLAKEBRONCO, I definently agree with almost everything you've said, and if I was building a rock crawler I would head your advice. The toughest part of any type of project like this is deciding how far to go with it. I've owned 3 Jeeps that I spent alot of time and money on. The main goal I had during building was ground clearance. What I found out pretty quickly though was that after tires, axles, suspension, engine mods, etc. I put way to much money into these Jeeps and did not really gain all that much except headaches trying to make everything work together. This build will be focused on being able to get out of any situation I get myself into. However, Im not building a rock crawler, choosing to turn back or take a different line can be a much smarter (and cheaper) decision than building a huge truck. Cutting the bed depletes my storage space. Also moving the suspesion would require a shorter driveline and most likely create a steeper angle so on and so on. I may however flat bed the truck and chop maybe 6-12" off the total length or even just cut out the lower bed panels and build a high angle rear bumper. Also I plan to move the front axle forward a bit during the SAS. With the suspension I am trying to use off the shelf parts that I can get any where in north america if need be. I want a reliable simple truck. Thats my goal.
and a ff or sf 14
