Price 450 KTM Rally:
29.300,-- Euro (without VAT)
Price spare engine (max. 2): 5.000,-- Euro (without VAT)
Bike painted in sponsor basicolor: 1.000,-- Euro (without VAT)
Production date: October 2010
Closing date (for orders) : 15th of June
For orders please contact
daniela.leidl@ktm.at
Pictures of the bike we will send you soon (1 – 2 weeks).
We are looking forward to hearing soon from you!
Best regards
KTM Rally team"
attached specs:
450 Rally Replica 2011
Engine
Engine type Single cylinder, 4-stroke
Displacement 449cc
Bore / stroke 97 / 60,8
Power n.s.
Torque n.s.
Starter / battery Electric starter / 12 V 8.6 Ah
Transmission 5 gears, dog clutch engagement
Fuel system Keihin FCR-MX 41
Control 4 V / OHC with roller rocker levers
Lubrication Pressure lubrication with 1 Eaton pumps
Engine oil Motorex, fully synthetic, SAE 10W-60
Final drive 15 : 48
Cooling Liquid cooling
Clutch Wet multi-disc clutch, hydraulically operated
Engine management / ignition Keihin DC ECU
Chassis
Frame Chromium-Molybdenum trellis frame, powder coated
Subframe Self-supporting plastic tank
Handlebar Aluminium, tapered, Ø 28 / 22 mm
Front suspension WP-USD Ø 48 mm
Rear suspension WP-Monoshock with Pro-Lever linkage
Suspension travel front / rear 300 / 310 mm
Front brake Brembo two-piston, floating caliper, brake disc Ø 300 mm
Rear brake Brembo single piston, floating caliper, brake disc Ø 240 mm
Rims front / rear Spoked wheels with aluminium rims 1.60 x 21'' / 2.50 x 18''
Tyres front / rear 90/90-21"; 130/80-18"
Chain X-Ring 5/8 x 1/4"
Steering head angle 62.5°
Trail 120 mm
Wheel base 1,535 ± 15 mm
Ground clearance 320 mm
Seat height 980 mm
Tank capacity approx. 35 litres
Weight (ready to race) under 150 kg (without fuel)
