RandomAbstract
Looking good. I am anxious to see if you like the decking material on the floor. (Curious minds want to know!)
Well I've been lingering around this site for several months trying to absorb as many as ideas as possible for my build. Your build has been the one that has mirrored my plans more than any other and you have done the original inspiration drawings that you saw real justice with your fab skills... I spotted the same google sketch drawings on the jeepforum that you used as your basis. The only real change I'm going to make from yours is to go with a torsion axle. I've been meaning to ask what gauge you used for sheeting the walls on your bed and the exterior/perimeter of your side storage.
I purchased the Kamp-Rite oversized tent cot (http://store.kamprite.com/catalog/Kamp-Rite-Oversize-TentCot-p-16146.html) about a year ago and have used it about a half dozen trips (2-4 days at a time). I won't camp without it unless I'm backpack camping. This thing is awesome
- minimal ground prep/worry about rock, etc.
- extremely weatherproof. I didn't use the fly last trip and stayed dry with a unexpected hail storm at 4am.
- quick setup (about 2 minutes)
- very comfortable (it comes with an integral iso-mat and I added one of my own)
- great ventilation (I'd guess about 60% of the side wall area can be opened with good quality screening).
I've read other reviews online before I purchased this one at Bass Pro on sale for approx $175, and the only real competitor was Cabella's. I have no experience with Cabella's, but I understand that theirs is much heavier. I also read that some don't like the double cot, because it has a frame support that run lengthwise down the middle that isn't very comfortable for a "romantic evening in the pines."
Keep up the good work! I'm curious to see how you "deck-out" the tail gate to lay flush with the bed flooring. I'm more carpenter than blacksmith, but I'm getting better at the later with each project.... I can't wait till the funding for the trailer is complete to start building this winter!
Your fab skills brought me out of the woodwork to say "Great Work!" Very thoughtful project and well executed. I love how you just decided to make your own tongue jack because you didn't like the other options.
Keep it up,
Brad
p.s. I still have some coffee in my mug, so let's get an update!![]()
Great work! Thats exactly what I need! Only I dont have the skills or tols to build my own lol. With a working top that would be the perfect trailer! Good job!
-Thanks for the info for the tent cot, I see them online but I haven't seen one in stores yet. Is there a hard base for the matress?? If the bar is in the way, can you place a board under the pad to keep the bar out of your back??? One more thing, is the fame steel or alum, is it joined with metal brackets or plastic?? Thanks for your info.
This is my first trailer and 3rd welding project. It's going slow and I am learning as I go. I like it but this thing is getting heavy. I'm going to need a crew cab pu to tow it. It will be strong though!
http://www.jeepforum.com/forum/f104/my-solidworks-trailer-build-909088/
LOLOLOL, I was just looking at your build the friday night before I left for a trip. Thats great. Yeah, great design!!!. I saw that you had more frame work than mine. As it sits, mine weights 660 to 700, it change as the trailer rolled of the scale. To be safe I will say 700lbs. I would think that is a good weight, not too heavy. What gauge sheet are you using and what gauge tubing wall are you using? You should be ok, I have a gene that is adding some weight.
Frame is 2x3 .120wall box is 2x2 .95 wall sheet will be 11 gauge. every other box floor support is 2x2 .95 wall. My neighbor said i needed more support on the floor. The box is 4ft x 7ft 4 inches. It is long enough to haul a street bike inside with the tailgate closed. Tires are 37" including the spare. I am shooting for under 1000lbs. Oh and the frame for the side boxes are .120 1x1. Like I said this is my first build and I didn't know how thick or strong to make things. I went heavy just to be sure. If I had to do it over I would do more research and go as light as possible. I might build another just for off road and make it smaller and much lighter. If this one works out it might become the one for more everyday all around use. It might get smaller tires and be lowered by time I get done. Yeah my spare tire isn't helping out in tounge weight either.
UPDATE:
I put on a set of 31" tires and found some rims that are narrower. Fits nicely but, doesn't look as mean as before. May be the white is killing it????
