Lubricants....
Mattm94
Any of you who've been on trips requiring water crossings run marine grade lube instead of auto grade in diff, t-case, etc.... ?
1911
The grade of lube won't matter once it's contaminated with water and mud; either change it after the trip where you had deep crossings, or move your vents up high.
Mattm94
Vents up high aside, marine grade lubes have emulsifiers that keep moisture suspended, reducing or preventing damage until you can flush/fill.
Anyone run automotive grade gear lube or witnessed the results in a "sealed" lower unit or outdrive?
Smudge12
