This old Rz
94-98 7.3L General Powerstroke Discussion
Need a 7.3 / 0 to 60 reference
Jump to Latest
Unfollow
1 - 2 of 2 Posts
This old Rz
Registered
Joined 3 h ago · 1 Posts
Discussion Starter • #1 • 2 h ago
Hello all,
I have acquired a 2003 E350 extended cab 7.3.
had it in a diesel shop for a checkup they said everything was fine and it runs as it should.
( I do have up pipe leaks) diesel shop told me not to worry they all have leaks.
Mind you this is a commercial diesel shop farm equipment diesel trucks excetera not a performance shop.
She seems to run fairly normal to me.. best description is it "chugs along"..lol
My question is my 0 to 60 times are 14 seconds.
and then my 60 to 80 times are also 14 seconds. So I'm looking at 28 seconds to get to 80 which is probably 3xs slower than a Prius...lol
Diesel shop said that is normal these are not performance engines in any way shape or form however I've read hundreds and hundreds of post people talking about being quick etc I don't believe these things can ever be fast however it sure would be nice to go 0 to 60 not and 60-80 in a reasonable amount of time.
The van is completely 100% stock.
Is this pretty indicative of average performance?
I did have plans to do the following
1.) 4in turbo back exhaust, no muffler version.
2.) Stainless up pipes.
3.) Tow ONLY tune
4.) Trans valve body
5.) Mild Turbo upgrade or replacement.
NO ... Big injectors H- pop, etc..
Just want to keep it simple and reliable and fix some oil leaks, which I have not been able to pinpoint m
Diesel shop said they leak oil everywhere from every place that it's.... normal.
I'm not going to rag on the diesel shop like I said they do mostly farm equipment and commercial truck fleets...I'm aware that I should find and fix as many oil leaks as possible and the pipes I've already 4 degrees pipes they're sitting in my garage.
Please let me know what you guys think about those performance figures......ideally I'm not expecting much but honestly I would really like to see about a 9 second 0 to 60 I think that would be acceptable and realistic?
Let me know if I am off base any advice is welcome.
It is what it is if these things are really this slow no worries I'll just deal with it.
Thanks...
Jump to Latest
Unfollow
1 - 2 of 2 Posts
This old Rz
Registered
Hello all,
3.) Tow ONLY tune
Thanks...
