05+ Tacoma Hood blackout?
Schattenjager
That is pretty funny -
I too have had a Buick Grand National and an older 911 that were black. Nothing looks better clean, but it only takes three minutes of driving to ruin that. White for me. Heck, it's the only way they would let me join ExPo...
Ive got the 2012 Trucks Covered!
http://crawlorado.com/ocart/index.php?route=product/product&product_id=76
TACO721
how well do these work? i have read a few posts on TW that guys said the glare was not bad from lights on the roof. but i can't say much. i have not really done much mods yet. since i did not know what i wanted to do, and did not want to waste money.
barlowrs
Do you do anything for the 05+ hoods wtih scoops though? I have shot you a few emails. I am very interested.
dcarlin
Regarding the '05+ sport hoods (ie. scoop)... I barked up that tree with Crawlarado and Vigg Designs to no avail. Vigg said they would look into it and I never heard back from anyone at Crawlarado. I ended up ordering 3 cans of Plastidip and just finished a test run on some scrap. Pics of finished hood to follow.
Just FYI but you can make your own for $8 and some auto mask tape. Just get some of the plasti dip back in a spray can. tape off your lines on the hood and spray her like you would anything. if you dont like it peal it right off like a sticker and do something else its perfect for this application.
barlowrs
Sweet...cant wait to see how it turned out.
dcarlin
Plastidip Blackout - Proof of Concept
To all entertaining the idea of a plastidip hood blackout... Following attempt #1, here are my thoughts and plans:
- Due to the amount of real estate involved, the biggest obstacle for me was laying down an adequate coat along the tapelines while still managing to pull the tape prior to setting of the "dip"... As evidenced by the pasenger side "shoulder-line" where the dip pulled up significantly.
- As with any aerosol coating, the key factor to achieving a uniform texture/finish is going to be maintaining a consistent spray distance and proper overlap. To achieve this on round #2 I will be pulling the hood and placing it on horses at waist level.
- I traced several convenient circular items on a "grid" of painters tape placed on a cutting board and cut out several different radii for use in creating the corners. The photo (poor photo) utilized a 5" diameter radius for the front corners and a 3/4" radius in the rear.
- Following the "shoulder lines" of the sport hood was actually harder than anticipated. I ended up pulling the truck into bright sun, making reference marks with pencil along the ridge, then pulling back into the driveway and taping to my reference marks. I would recommend low-adhesion painters tape as I managed to pull up a good sized piece of hood paint during the process.
- Since my truck sat in the sun all day prior to this attempt, I ran cool water over the hood prior to starting. This helped, however I'm 99% confident in saying that this is an indoor project only (at least in socal).
- It seemed to work best laying down the "middle 90%" of the hood and building the dip up to adequate thickness, then hitting the edges quickly and evenly... thus minimizing the tape exposure time.
- There are a myriad of instructional videos on youtube related to "dipping" everything from rims to hoods to entire cars. Check out dipyourcar.com for examples, links, and info.
In a nutshell, I consider today's attempt a solid proof of concept. If it weren't for the pulling of the dip along one edge, the silver-dollar sized piece of hood paint that came off with the tape(unrelated to the plastidip), and the slight variation in texture, I would be quite happy with the result. Round 2 will be performed at waist level, in the garage, and potentially in 2 stages (ie. work the left side of the hood, pull the tape, then do the right side with adequate overlap to blend the two). Hopefully this will get me closer to the original test panel I sprayed which turned out excellent.
I hope to see some other folks get inspired... $8 for an afternoon with the truck is cheaper than gas...
Unorthodox
I dont have the number handy but Krylon Camo Ultra Flat Back has about the lowest albedo of any paint you will be able to just walk out and buy. For probably $8 a can its a winner to me :sombrero:
DblD
My Crawlorado hood black-out has served me well on my '09 Tacoma. I first put a vinyl hood black-out on a '98 Discovery. The truck was white and the hood black-out helped with glare coming off the relatively flat hood. On the Tacoma there is a body line that runs across the back of the hood (between windshield washer and cowl). I was constantly getting sun reflection and glare from this body line. The black-out has totally eliminated this. Great product and service from Trevor at Crawlorado.
dd
Wainiha
I new here. I have been thinking about blacking out my hood as well. My LED light bar causes some unwanted glare. Looking foward to some learning here and doing some planning for the future.
I realize this not my year of truck but the same applies.
sumnrfam
Retired or just tired….
Here ya go
So,,, Super white,,and the non functional TRD hood scoop and direct sun,,, = GLARE!!!!
After our National parks trip in April (9 parks 8 days) including 2 looong days in Death Valley,, the glare from the white hood had to go....
A quick trip to my window tint guy,,and some 3M matte black vinyl mask later,,, & .......
Rocky Mountain Window Tint (Sacramento ) did a great job!, I have since removed the scoop insert & wet sanded and painted 3 coats of black satin,,
Hope this helps :sombrero:
wade
dcarlin
Plastidip Round 2 Complete
Following up on my previous post, I have completed my second attempt at a Plastidip hood blackout for the Tacoma Sport (ie scoop) Hood of my '06. This time around I removed the hood and painted at waist level. Similar to the first attempt, I sprayed the majority of the hood in even layers until an adequate thickness had built up, then sprayed quickly along the tapelines and pulled the tape immediately. What I changed up was, after stripping the tape, I spent considerable effort "fogging" the hood to diminish/reduce the signs of overlap. A rag with a small shot of WD40 cleans up any overspray with zero effort. Lastly, I retaped the hood back to the clean edges and applied 2 additional coats before calling it. Total expenditure was 3 cans of dip at $7 a piece and some low-adhesion painters tape (see patch of hood paint that came up during round 1). At this point I'm calling it a success, however it was definitely one of the more deceivingly PITA projects I've done in recent memory. I've built up a decent skillset with an aerosol can and have never had to work so hard to maintain an even surface texture and finish.
I'll try to remember to leave an update once this thing has some miles on it...
