'08 Pathfinder V8 Overland Build-Diesel Heater, Sleeping Platform, Sink, Sprayer...
N.Y.X.
Thank you!!
So I mocked these mounts up for my 20" alley lights. This will keep it low profile and under the awning on the pas. side. I should be able to cut, clean up, bend and weld directly to the rack. On to my least favorite part.... wiring :(
524160524161524162524581524582524583525726525727525730525731
bigskypylot
Love what you did with the storage space above the switches. I'm doing the same thing using my factory switch plate and switches above. The Xterra center console is coming out and we are replacing with a V8 Pathfinder center console, More details to come in my Phase 2 post :)
Sent from my SM-N960U using Tapatalk
N.Y.X.
I just had the extra blanks from the xterra and they just so happen to fit mostly perfectly. I'll add one more switch blank and make a finishing plate for it.
N.Y.X.
Added some theft deterrence; Cable, Bike Lock, Padlocks, but it's parked inside if i am not using it. Also saved some room and added quickfists to the backside of the awning. They're on the passenger side so should be safe for accident purposes. I'll likely wrap a long cable around them and the awning with a padlock as well.
526185526186526187526188526189526190526191526192526193
N.Y.X.
Built my light mounts! Left my rig at my buddies so he can measure up for some custom sliders.
526503526504526505526506526507526508
kootenay
Intergalacticsuperintendent
Building is look great, not sure if it was already mentioned, but be very careful with the propane tank inside the vehicle.
N.Y.X.
Thank you Kootenay, it's always a good thing to mention. I did my research and just was set on utilizing that space for transport only. Then I thought of a rear pas. lighting something and we go boom. So at the moment, it's transported on the roof rack :)
More progress...
