With cash being no option, I would opt for an 8D 12v AGM battery (lifeline brand are superior). Better performing in most ways, easier to wire etc.
Pros
Higher charge efficiency
No offgasssing
Charges faster from alternator or high current source
Can be mounted on side if needed
No adding water
Better vibration resistance
higher cycle life (when charged and treated well)
more compact (less volume than flooded GC2)
Cons
Heavier than a single 6V (harder to move around)
More expensive
Cannot measure SOC with hydrometer (good SOC meter suggested)
GC2 batteries are a good option, I have used them in the past. They will need watering, and ideally a vented enclosure. They have a higher internal resistance so they will charge a bit slower, and have higher charging losses. They are much cheaper than AGM. They will tolerate outright abuse better than AGM in general.
The physical separation provided by AGM batteries glass mat makes them more resistant to shell shorting. This allows for more plates per cell. This means in generally they can accept higher charge currents, and supply higher discharge currents. This is why many AGM deep cycle batteries can double as starting batteries, as they have sufficient surface area to make good cranking amps.
If you have enough charging, space, and weight capacity, 4xGC2 in series/parallel will provide a 400AH bank. Obviously you need sufficient charging, otherwise sticking with ~220AH is best.
