Do you have an Anderson connector tool. I think you can crimp on a connector, and use the crimped sleeve instead of bare wire, or you could tin the wire ends with solder. I can make one up and take a picture if it helps.
If the panel is old, or damaged, partially shaded it is possible to not get full output at all. Do you know someone else who has solar panels so you could do a little testing? My personal experience with 100w / 90w panels is about the best I've seen is 5amps. Your actual mileage may vary, for cheap ones, maybe a lot less.
Bear in mind, the solar power generated here is strongest in the morning, my 1pm here, it's not generating nearly the energy as first thing. Try again earlier maybe?
CA seems to be heavily saturated with Solar stores, perhaps there is a place around you?
