100 Series Land Cruiser Brake Replacement/Upgrade (and rebuild) with Pics!
rionorte
Thanks Kevin. I dont have a 100 series yet to fix the brakes. But the pics make good visual resource when I do my front 80 series wheel bearings. :bowdown:
adventureduo
Dave Druck [KI6LBB]
But i thought you're going solid axle? Why waste the denero on a brake upgrade on the IFS? Sweet set of rotors by the way.
DBS311
Kevin doesn't know it yet but when he goes SFA, I'll be buying his brake setup from him for my 100 (unless these brakes work with the factory solid axle as well).
RAM5500 CAMPERTHING
OG Portal Member #183
Correct. However, the brakes on this thing were so bad it was almost not even driveable! I need something, so i figured i would install an upgrade that i have had good luck with in the past!
Because i will be driving it with IFS for about 10-12 more months and wanna stop!
Thanks. 3rd rig i have had them on, very nice upgrade!
Hltoppr
El Gringo Spectacular!
Geez....like your brakes weren't good enough to begin with! Try using four wheel drums!
-H- :bowdown:
RAM5500 CAMPERTHING
No, these things were some of the worst i have ever seen when i got the truck, TOTAL metal to metal with VERY deep grooves on all 4 rotors!
Been there, done that! :D
