plainjaneFJC
Deplorable
2004 w/5 speed.
I went to do the pan only fluid swap, drained 2.75 qts out. Went to install new and realized I don’t have a dipstick…I know I should have researched this first.😆. Well I didn’t have the 24mm socket or transfer pump needed to fill it back. I was looking right above the pan and removed a small 12 mm bolt- I was able to use the pump and hose I had to add the fluid back, my question is I assume that’s OK? Any transmission experts?
