100AH Lithium cant handle start up draw
luthj
Engineer In Residence
Eventually We will see a standard arise. Something like the CANbus used on the Trillium batteries. Simple, universal, easy. Every device can get/send critical info, such as temps, current limits,etc. All that can be relayed to a monitor if needed.
john61ct
Yes, I've never seen "a BMS" I'd rely on much.
Most useful as a concept, collection of functionality required, overlapping for redundancy, at cell vs pack vs bank level.
shade
Wouldn't you rather use data coming directly from an internal BMS to derive your custom charge parameters? Seems like internally measured cell temps & voltages would be more accurate than external readings.
john61ct
I do not know what an "internal BMS" would look like. Voltages measured right at or near the cell terminals is as good as it gets.
There are many ways to get per-cell voltage readings.
Any such circuitry needs to be easily removed, replaced, isolated from the cells as needed.
I have also never heard of cells with embedded temp sensors, but would be an interesting idea. In fact temperature measured between cells within a pack is really just as useful.
If your use of the bank is causing temperature issues, you're doing it wrong.
shade
By "internal BMS", I thought we were discussing the management systems built into LFP batteries, like Battle Born offers.
john61ct
No, I have been very clear at least for myself that no drop-ins are suitable.
And the inaccessibility of the BMS is a major reason.
shade
To broaden my palate, what LFP battery in the 100Ah range would be suitable for you for use as a house battery in a camper?
john61ct
Systems: OPE-Li3 (Lithionics/Ocean Planet), Victron, MasterVolt
Bare cells: Winston/Thundersky/Voltronix, CALB, GBS, Sinopoly and A123 (now Lithium Werks / Valence / Super B)
shade
Do you own a system based on any of those, or do you just use them at work on your submarines and rockets?
john61ct
Sorry, I thought you were sincerely asking my advice. I certainly answered sincerely.
I have never worked in submarines, but yes some aviation.
Most of the systems I've installed are on boats, but off-grid homes and liveaboard land vehicles as well.
I choose what details I want to share, usually as much as possible given the circumstances. If I remain silent on an issue it means I have nothing to contribute on that specific matter.
I've been revising my standard write-up for care factors designed for maximum longevity, will post in due course.
I realize there are those here with commercial interests to protect, but hope the intention of the forum management is to allow objective information and a wide range of opinions be presented to the membership as a whole.
shade
I appreciated your post in the spirit it was made. I really was curious about what's available. I was kidding about the submarine and rocket, but the sources you listed make that grade of products.
I've read enough of your posts to know you were going to point to the high end, and I'm completely ignorant about that space. If I go LFP, I'll end up somewhere in the middle of the quality/price spectrum. I doubt I can justify the cost of top tier gear, but I also don't want to buy no-name junk destined to burn my truck to the ground.
Since you mentioned Bruce Schwab, I'm also curious about Firefly carbon foam AGM batteries. One of those might be a good fit for me.
luthj
John61ct is using his previous standards. Personally I think they are much to stringent. We aren't working on deep water marine vessels or aircraft. We have a much higher tolerance for failures. He is also comparing early quasi experimental drop-ins (somewhat unfairly) to the newest crop of drop-ins.
While I agree that they are not perfect, the consistency of cylindrical cells has improved dramatically in the last 4 years, and electronics quality control scales with volume. While drop-ins are fully not mature, they are passing the early adopter stage, and moving towards mainstream in our applications.
john61ct
Cylindricals are a whole 'nother category.
While widely used for eBikes and skateboards, I would not use those chemistries for DIY House banks inside a living space.
LFP in that format is hard to find at reasonable prices per kWh.
And per-cell monitoring gets unweildy when you are working with hundreds of them.
shade
The main failure that concerns me is something catastrophic, like a fire. From what I've seen, as long as a battery isn't sourced from a no-name supplier, that doesn't seem likely. Beyond that, I'm sure using the very best LFP batteries & chargers yields the highest performance and battery life, but I'm not sure the cost is worth those benefits for me.
flipstick
