I use SEM Rust Shield in gloss black (part # 38061) and SEM hardener (part # 38008). It's harder and glossier than POR-15 and stands up better too. Because it's hardened it is far more resistant to chemicals than POR too.
No real need to sandblast unless they're really bad. Wire wheel on a grinder, pressure wash with good soap, wash down with brake cleaner and you're good to go. And use a brush...No need to spray axle housings. This is the same way I did my last set of axles 4 years ago and they're still perfect. Well, except where they got sandblasted from 1100 miles on gravel roads up in James Bay this past summer!
Thanks Jim. I can get SEM through my local auto paint shop. I never liked POR myself, It always seemed to get a chip which would rust then the whole thing would peel off like bad powdercoat.
Now, I'm sure I've got the wrong vocabulary ... since this paint uses a hardner, that means its "catalyzed" (?) and I'll toss the brush when I'm done, right?
Some more progress in the past couple days. Got what amounts to a rolling chassis. Engine, drive shafts and probably exhaust are next. I was trying to get the motor in by March 1st but I guess I'm going to miss that.
I love watching this 109 come together! Several years ago a neighbor was going through this same type of first class build. I'd forgotten how much I enjoyed stopping by each week to see the progress.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
