12 volt and USB Flexible neck LEDs
Letsgo01
I came across a couple of interesting and inexpensive LED lights that I am using above my bed in the Van. One is made by Mighty Bright and it has 2 bright LEDs with a convenient on/off switch so I don't need to unplug it. It has a flexible neck to point it where you want it. It is USB powered. I have a two port adaptor that cost $5 that converts one of my 12volt receptacles to two charging ports, one for an ipad, the other for my cell phone that I also use this light. I share that with either of the two receptacles over the bed. The other light is made by Bell and cost similar to the Mighty Bright ($7). It has blue LEDs with a bright output and flexible neck that holds it in any position. It utilizes a 12 volt lighter type port. Again, the on/off switch that most 12 volt lights don't have is very convenient so you don't need to unplug and store it when finished needing it.
Dgollman
