zukrider
i have a trade offer on my samurai, for a 12V cummins. i really want the cummins for my suburban, so im quite interested. here are the emails i have so far.
1-Interested in trading for a cummins diesel with a CAT turbo? thanks
2-it is just the engine. it came out of a 92-93 dodge. It was used at the local college in their diesel class. they cleaned up the head and lapped the valves. installed a new head gasket and valve cover gaskets then ran it on their test stand. the engine is clean and comes with a CAT turbo and a flexplate. I also have a caddy 500 with a ton of high performance parts if that might interest you. . thanks, David
3-It has a rotory fuel pump, intake, exhaust and a flex plate. the alt bracket is there but no alt. it has a heat exchanger on the side. no fan or power steering pump. the engine is clean. I have a starter and it can go with it but it is for a 24 valve and has the wrong nose cone. it is brand new and you could swap on the right nose cone. it unbolts from the rest of the starter. let me know if there is anything else. thanks
im ok with the value of the trade, so long as the engine is operational. i am not a "diesel" guy, so finding parts is gonna be difficult. also, the learning curve forthcoming will be fun.
So what do you think? list any questions to ask, and ill pass them on!
thanx
joe
thanx
joe
