TWX
Hey all,
Have a '15 Nissan Frontier SV 4x4 Crew Cab with the 6' bed, looking to do some fairly simple upfit to make it more capable for backcountry and crosscountry use for a small family.
So far I've put on Trail Ridge towing mirrors, installed an aluminum engine skid plate, and replaced the 16" alloy wheels and all-seasons with 17" steel wheels and Goodyear Wrangler Duratracs in 255/75/17. I'm looking to build a replacement front crash bumper with a 2" receiver so that I can use a slide-in winch that could be used front or rear, to add heavy gauge cabling for power to Anderson connectors at each end (I have a bunch of 2/0 welding cable looking for a use) and installing a dual-battery setup to power said winch off of an aux battery and for jumpstart connections and possibly other uses. I have a diode-based isolator, looks like it's for an older car that needed an exciter wire lead off of the primary, hoping it can be used. Also likely going to swap in some Pathfinder V8 front coil springs for a little more ground clearance and the bigger brakes that require those 17" wheels.
Suggestions on resources for installing the dual-battery setup would be appreciated, especially how to go about tying-in to the existing electrical system without messing it up.
The truck as it sits now:
Down the road I plan to build a replacement rear bumper for it (I've already bent the factory bumper) and possibly build a new hitch with more ground clearance into said bumper, and I may make some rock sliders. I'm not planning on doing a lot of rock crawling with this truck and the frame is pretty wide as it's the same width as the Titan's, but some moderate extra protection wouldn't go amiss either.
I do have a cab-height camper shell as well as a flat fiberglass tonneau cover, those get swapped on when I don't anticipate using the truck for bulky cargo. Haven't decided if I want to try for some kind of side-in camping accessory, a camping trailer, or something that could swap-on in place of the bed for trips. I assume that the last is the most versatile because it's not necessarily constrained by the dimensions of the bed, but quite pricey.
