offroadrunner
This LandCruiser needs a good home. I started to make it a reliable camping/expedition rig but need someone else to take over. This is a great candidate for a V8 or Diesel transplant or keeping the original motor like I was going to do.
I am asking $3500
Price drop:$3000 OBO
I will check this site periodically but email is best morganloncle@yahoo.com
http://www.flickr.com/photos/62411119@N06/
Come see it and drive it :smiley_drive:
Cruiser has 72 F motor, 4sp trans, rebuilt carb,
rebuilt steering box, replaced tie rod ends/relay rod end, drag link.
Brakes changed to dual circuit set up(ready for your disk brakes)
rebuilt wheel cylinders
rebuilt power booster (FJ60)
rebuilt master cylinder (FJ60)
adjustable proportioning valve
extended front brake lines
Parking brake
good used drum/ pads
output bearings
new sway bar bushings, new motor mounts
New in/ex manifold gasket
Rear axle overhaul, seals/bearings
Add-a-leaf 1.5" lift
31x10.5x15 BFG A/T with very low mileage on white wagon wheels
Back power window works
Sunroof
Body is in above average condition for a FJ55. There is some rust in the roof panel of the truck, as well as under the rocker panels. There are a couple of rust holes in the front floor pan.
The front doors are sagging a bit on their hinges, the hinges need to be drilled for new pins or buy already rebuilt ones. Front doors are also a little loose on the latch side.
I am asking $3500
Parking brake
output bearings
Sunroof
