1983 FJ45 Troop Carrier Buildup
taco chaser
Supporting Sponsor
rusty_tlc said:
I saw that last time we went to Death Valley. Theres one for sale in Big Pine too.
Yeah I don't know what there asking but there's been alot of work already done to it, looked like a 350 was under the hood by the looks of the header, and if I remember correct possibly an Atlas t-case.
taco chaser
Supporting Sponsor
HelaJames said:
I live up in Fallon, does anyone have contact info for the 45 in Minden?
Scott/ burl40 took a picture of the phone number when we were there, try to PM him, if that dosen't work I'll call him if your still serious.
Hltoppr
El Gringo Spectacular!
Carpet and spacers came in today!! I'll hopefully have some time to install 'em....and the tires, and get some pics up! ....but we are supposed to get some pretty good snow tomorrow as well!
-H-
MoGas
Central Scrutinizer
-H-
I'm going wheeling in Sedona tomorrow, So my driveway won't be available till Sunday.
Hltoppr
You need to build a big garage for all of us to use....hint, hint...
Let's see how much snow we're under.....
-H-
Hltoppr
Busy Sunday!!
Finally had the opportunity to start installing some of the stuff I've received!
Spidertrax 1.5" bolt on spacers helped to give plenty of clearance for the wheels....These things are nice! (Sorry about photo quality...it was 26 degrees and snowing all weekend!)
....and then started to remove the rest of the old advertising...
I could tell every time the phone numbers changed....:rolleyes:
....And I can still fit into the garage...and out again, with the new rubber!!!
:punk03:
-H-
Grim Reaper
Hltoppr said:
Busy Sunday!!
-H-
Did you sand the surface of the hub clean so those would seat?
I would recommend at the very least loctiting the nuts. Double Nut might be even better if there is enough stud.
I had a set of those on exactly 45 miles when one came loos at 65MPH.
Hltoppr
I wire brushed the surface, and used loctite red, along with torque to 105 ft/lbs, per instructions. I'll re-check 'em after about 25 miles.
-H-
YaRiteZ71
