1986 Toyota 4Runner⎮Rebuilt Engine⎮OME Suspension⎮New Tires
zelseman
Year: 1986
Make: Toyota
Model: 4Runner
Trim: DLX
Mileage: 200,00X on body|<5,000 on rebuilt motor
Engine: 22RE 4 cylinder
Transmission: MANUAL
Location: Tahlequah, OK with delivery option to OX EAST in October
This 4Runner has been a dream come true for my wife and I. We have always wanted one and took the opportunity to buy this one while we were traveling full-time. This truck has been extremely reliable and has never let us down. The only reason we are selling is we stopped traveling and we got a great deal on a GX470 and want to build it instead. We have too many projects and this one needs a good home.
Interior
We added a vinyl floor kit with reflectix underneath for sound and heat retention. The radio has been replaced with a cheapish head unit and all four speakers were replaced a year or so ago. The antenna was replaced a couple of months ago.
The seats have seen better days but the fronts have canvas seat covers. The rear seats have been stored inside since we have owned it as we don’t have a need for rear seats. They will be included but not installed.
The back has a wooden platform bolted in for a fridge/cooler and a slideout for a camp stove. There is an auxiliary second AGM battery wired to a relay under the hood for charging while driving plus there is a solar input Anderson connector wired into the charge controller. A 3-circuit switch was added to the left of the steering wheel to control the front light bar, rear lights, and battery charging. All electrical additions are relayed and fused. An aftermarket tachometer is installed on the left of the steering column.
  • OC Auto Parts Vinyl Floor
  • Sony Head Unit
  • Duracell GC2 AGM Battery
  • Renogy Solar Charge Controller
  • Blue Sea Systems Fuse Box
Exterior
The truck is fairly identifiable from the roof rack, custom made from an old NWOR roof rack. The rack is bedlined and can be used with or without the topper installed.
The paint job was done in the driveway a few years ago and is showing some wear. It looks great from 30 feet but could use a respray if that type of thing is important to you. The topper has a fresh coat of bedliner and is easy to tough up if needed.
  • Custom Roof Rack
  • Trail Gear Front Bumper
  • Custom Rear Bumper
  • Front light bar
  • Rear back-up/Scene lights
  • Pro Comp 51 Wheels
  • General Tire ATX 31x10.5x15 w/ 5000 miles
Engine
Freshly rebuilt 22RE by Mick Henson (ASE/Toyota Certified). Engine was rebuilt at 195,000 miles, was broken in and then taken on a 2,500 mile trip to Colorado and back with zero problems. Clutch was replaced around 191,000 miles in December 2018.
  • LCE Radiator
  • LCE Header
  • LCE Radiator
  • 2.25” exhaust
  • Optima red top starting battery
Engine build details:
  • rebuild kit 467.90
  • pro head stud set (arp) 0.00
  • pro efi camshaft 429.90
  • rocker arms 0.00
  • rocker arm adjusters w/ nuts 0.00
  • intake valve x4 19.80
  • exhaust valve x4 27.80
  • timing cover 79.95
  • shipping 42.06
  • engine break in oil 21.98
  • ngk spark plugs 11.96
  • hose clamps 2.99
  • engine degreaser x3 10.17
  • engine paint 5.99
  • toyota pink coolant x2 47.98
  • oe toyota headgasket 55.95
  • fipg oem gasketmaker 9.99
  • new throw out bearing 0.00
    • vat head/block/rods/crank
    • hone block cylinders
    • resurface block deck
    • resurface cylinder head
    • regrind valve seats
    • install new valves
    • assemble block/crank/rods/pistons
  • machine work total 480.00
  • remove and reinstall engine 10.0hr 750.00
  • tear down engine 3.0hr 225.00
  • assemble engine 4.0hr 300.00
  • remove all emissions 2.0 hr 150.00
  • total labor 19.0 hr 750.00
  • new rocker arms and adjusters 250.00
Total 2450.00
Brakes, Suspension & Steering
This setup is nearly perfect for our travel style and is a great balance of capability and comfort. The rear springs were replaced when we bought the truck and the torsion bars were replaced recently. The suspension needs nothing.
  • Bilstein 5100 Shocks
  • Old Man Emu Leaf Springs
  • Old Man Emu Torsion Bars
  • Old Man Emu U-Bolts
  • Marlin Crawler BJ Spacer
The steering system was completely replaced in 2019 with MOOG parts.
  • Idler Arm
  • Pitman Arm
  • Tie Rod Ends
  • Tie Rod End Adjusting Sleeve
  • Ball Joints
The brakes have newish pads and a new brake caliper on the driver’s side a few months ago. New brake fluid as well as speed-bleeders on each corner. Most recently replaced the Transfer Case Rear Output Shaft seal with an OEM seal. Replaced the TC fill plug with a trail gear plug and refilled with Royal Purple gear oil.
Spare Parts
Included with the truck is a handful of parts that we have accumulated along the way.
  • Functional tailgate with unbroken glass and a functioning window motor
  • Lightly used Bilstein 4600 shocks from when the truck was stock-ish height.
  • Miscellaneous trim and pieces
  • NEW in box NAPA DS CV Axle
  • NEW in box LCEngineering Wheel Bearing Kit (preventive)
Known issues
  • Power Steering system drips a drop of fluid once a month. Was never enough of an inconvenience, plus rust prevention.
  • Driver’s side CV boot is torn. A NEW replacement NAPA CV is included with the truck.
  • There are a few small areas of rust, mostly around the rear fender wells and some surface rust under the truck. Most of it has been sanded down and treated. There is surface rust in different places, but the frame has zero rust and all is cosmetic.
  • The muffler has a hole from the driveshaft letting go. The sound isn’t so bad, but it is louder than with a muffler. The driveshaft and u-joints are new.
Price is $10,000 and the truck is located in Tahlequah, OK. I am willing to meet within 100 miles or farther for the right price. Will come with a fresh oil change and a full tank of gas. We do not NEED to sell it and the demand for these vehicles continues to grow. I will continually tinker on the truck and as I repair small things, the price will become more firm or potentially go up as I move through it.
Additional photos: https://drive.google.com/drive/folders/16PPe5trl6c2gfyoFXkjHcot2IphYwDIy?usp=sharing
Breezy78
