speedpin
1987 Land Rover Defender 110, Rebuilt 200tdi, New Ashcroft R380, Upgraded Needs NOTHING. $24,000
I purchased this 110 last year and have completely gone through it. Has been on several off road events, not mudded, and is ready for the next. I drive it several times a week, 40 mile round trip up the interstate at 70 MPH and have taken it several hours to events, no problem, 28-30 MPG. Small black puff at start up and clears up very quickly (Thanks to new rings ). If it works out I will transition to a 5 door Defender, if not I will continue to enjoy it.
Link to many more pics
https://goo.gl/photos/rc7e3s9kMVNCdX896
The drivetrain:
200tdi from a 1991 Discovery
New timing belt and pulleys
Crank seal
New Water Pump
New Elring head gasket
Removed, inspected piston
Replaced big end bearing
New rings on all pistons (rehoned cylinders "cross hatching")
New Garrett Tubo /manifold, wastegate
New Conversion Downpipe
Injectors pop tested, new washers
Rebuilt head (pressure tested, valve job, and valve seals)
Genuine LR clutch and throwout
Converted to Power steering (works great)
New Ashcroft R380 Stumpy gearbox w/ linkage and all upgrades, HD bearings option, and higher 5th gear
1.4 Transfercase (resealed with new Ashcroft cross drilled input gear)
Axles factory and maintained
HD steering link and TREs
Front diff Skid
Front steering skid
HD flanges (should get them in the mail next week)
Exterior:
Nice MOD 3 door, straight and 95% corrosion and rust free (Minor surface rust if any)
Converted to civilian lights
Truck cab
Also comes with a Full MOD hoop set with header bar and green canvas softop to turn into a soft top.
Been resprayed two years ago and looks great
Rocksliders with tree bars
Rockware bumper w/ brushguard . LED spots
LED flush mount reverse and utility lights.
New Superwinch 8500lb
Snorkel
MOD roll bar,
New Pioneer kit (pick and shovel)
OME 2" springs
Brand new BFG KO2 235/85
16"Steel wheels
Interior:
Tithonus acoustic/thermal matting system
New front Exmoor highback seats
NAS door cards
Very Nice NAS forward facing rear bench seat. Fold and tumble
VDO gauges EGT, TEMP, Boost
All lights and gauges work as they should
Blade fuse box upgrade
$24,000
Turnkey. Needs Nothing
# -7038 5016twothree-
Let me know if interested
Located in Fredericksburg VA
Trade Trades for 5 door defender
The drivetrain:
Crank seal
New Water Pump
Front diff Skid
Front steering skid
Exterior:
Truck cab
Snorkel
MOD roll bar,
OME 2" springs
16"Steel wheels
Interior:
NAS door cards
$24,000
