1989 GMC Suburban "Trail Boss" conversion
mep1811
Gentleman Adventurer
So heres the bumper I got hosed on. At first I was pretty mad about it, and I could make the excuse that it was at night, but theres times where you just have to accept when you get hosed.
I stood there for a while trying to decide how to fix it, and none of the options were that appealing at the time lol, SO I just started building.
Winch mount
the receiver runs the full depth of the mount, with a cross plate under the rear and the cross plate in the front, theres 10 bolts holding it on (4 in each side and 1 in each top frame rail)
It sticks out a bit but I didnt want to cut the grill on this one, it sits higher than the stock bumper, and I think less than the Warn knock off would have.
planning on de-fanging it
But now I need to finish the bumper, I am going to run some 1.75 tube (red) out to the sides and wrap it a little but teying to decide if I want to put a hoop (blue) over the top and maybe leaned out a little bit or put a second tube (yellow) that would go behind the red one and plate the top of it? I have two 5" or 7" lights I want to mount on the front also.
Please dont be jealous of my mad artistic skills lol
That was a nice old school winch bumper . I bet you can sell that
warrpath4x4
think I figured out the running issue ( i hope), Its only getting 8PSI of fuel pressure at best. I picked up a fuel pressure testing kit from harbor freight with the GM adapter (man was that a pain in the a** to put in). fuel pressure ranged between 6-8psi and should be 10-13.
was going to cut an access hatch through the floor but someone has been here before
picked up a new pump and strainer but it will have t wait till after Christmas.
warrpath4x4
spent most of my New Years Day pulling the axles from my stepside, tore the rear down, welded up the undercover fab diff cover, and stated putting the rear back together.
ive seen people put an axle shaft into a vise then put the carrier on it to torque the ring gear bolts, I gave it a try last night but it just wasnt working since the shaft is not the same thickness the whole way and it just kept trying to spin the shaft out of the vise. So it was back to the trusty way ive been doing it.
warrpath4x4
I need to get some wheel bearings and seals for the axle so last night i went out and bounced from thing to thing. I could not get the wheel bearings removed with a slide hammer and the attachments I have, ended up destroying the driver side and just leaving the race in the tube. Looking around the shop I found a piece of thick wall exhaust tube that I am going to use to build the steering column for my samurai. It worked but it still took a ton of beating on it and mangled the ends of the exhaust tube.
pulled the pinion bearing off the old one to get the shim off. Both the new and old pinions have the same pinion depth number on the ends so setup should be fairly easy. My cheap harbor freight digital caliper i bought 15 years ago finally died so I need a new one.
Then I clearanced the old pinion bearing for a setup bearing with a small belt sander.
I "should" have the rear axle back together this weekend.
warrpath4x4
I was fed up with the stumbling issue after replacing almost all of the related components and ordered a new intake to accept a carb and all the associated bits. Being an OBD1 theres only so much testing I am capable of doing, I was recommended to get a bluetooth tester for it but thats even more money and a laptop or phone that I dont have and theres no guarantee it was going to "show me the light" lol since this thinig does not show any codes or CEL lights as is.
So i went out to start the change over to a carb (waiting for a fuel pressure regulator to show up), pulled the intake and the EGR ports are completely blocked
Now I am wondering if i should just clean the ports, throw it all back together and test again... or just say forget it and go carb?
also (maybe unrelated) there is a bunch of what I am guessing is carbon buildup on the driver side of the engine in the valley, at first I thought it might be a shop towel it was clumped up that bad. Most of the bolts on clamps and brackets were all loose or half installed telling me someone was in here before.
warrpath4x4
last couple of days ive been spending a couple minutes cleaning the engine valley till it gets dark then move into the shop and work on the rear axle. While the valley is not as clean as I would like (without tearing the engine apart), it is better than it was. I figure I will run some ATF in the oil for a couple of trips then do an oil change.
I like to paint my diff covers, engines, and stuff like grey or a lighter color, it makes finding oil leaks easier than black on black... but this aint it lol
wife brought me aluminum color, the cap looked silver, in person it almost looks like spray paint chrome lol. thats gotta change. But i got the 4.56 gears and posi setup in it.
warrpath4x4
sometimes its the small things that irritate you the most.
I spent a good penny on this paint thinking it was going to be a better paint
but after 5 coats of paint you could still see the marker underneath it
and bare metal showing through
quick trip to trusty Ace hardware
and we have a painted diff
warrpath4x4
Last week driving the suburban around with the floor still open over fuel tank I could hear some gear train noise, While I have the new rear axle done I am not ready to install it yet. Tried to pull the fill plug on the rear axle and just rounded it out. I need to weld a bolt to it and I can get it out. Figured while I was under it I would check the transfer case also Pulled the fill plug and about got hit in the face as 2-3 quarts of fluid came shooting out... great. So i get to pull the transfer case out and replace the input seal and the output on the transmission while im in there.
The I came down with this cold that's been going around so I have no done Jack
warrpath4x4
I finally feel well enough to get back to work on this thing after dang near a month. Sunday I degreased and wire wheeled the majority of the housing and got it moved into the shop. Last night I started stripping it down.
But while I was down and out, the suburban was nominated and voted as GM of the month over on CK5.com
warrpath4x4
Its been almost 3 weeks since I have done anything on this thing besides going out and firing it up once a week. Between scouts, being sick, snow storms and cold temps, I have not wanted to go do anything with it. Well tonight with a torrential down pour I finally went back into the shop lol.
I drilled and tapped the hole for the Zip Locker
I knew the breather was plugged and i cleaned it out as best I could with a pick and brake cleaner but wanted to clean it better, when trying to get it out of there the way it was bent over it was hitting the housing. So I spun it back around to try and bend the tube up and the whole thing just popped out. As you can see theres about half a thread in the housing it was threading into.
(after cleaning the hole a bit)
Well now i can get a fitting with a pipe nipple and be better off
I have seen people running ARB lockers and drilling a hole inside the housing and using a machine screw and P-clamp to secure the copper line to keep it from vibrating into the ring gear. I am wondering if anyone has done the same thing outside the housing to attach the air line and maybe the breather tube so theres less chance of them getting ripped off?
Im thinking in this flat spot where the yellow spot is
warrpath4x4
this thing has been a thorn in my side for months, if not year and it all (maybe not "all") came down to this stupid hose
This hose/tube goes from the EGR solenoid to the EGR. I used tunerpro RT and a USB OBD1 cable and it was reading high manifold pressure. I went out tonight and replaced the hose from the throttle body to the PCV valve and capped all the connections between the TB to the MAP sensor, the EGR to the EGR solenoid, and the EGR solenoid to the TB.... and it ran great. So I started putting hoses back in place one at a time, I put all back on and testing and it ran great until I put the one between the EGR and the EGR solenoid. Pulled it back off and capped them again and it runs great. Both EGR and solenoid are new, the problem existed with both of the old parts and I cannot see any issue with the hose/tube but i cant argue that thats not where the problem is lol.
So then I pulled the running boards/fender flares
