ffdawson
Go Somewhere!
SOLD SOLD SOLD!
1990 Toyota Land Cruiser FJ62
Beige Metallic (Factory Color Code 4G8)
Brown Interior
248K Miles
Original Drivetrain. 3FE Fuel Injected Inline 6 Cyl and Automatic Transmission.
Factory 4x4, manual locking front hubs.
Zero rust! 100% California (Bay Area) car for its whole life.
Pink Slip in hand, registered until Jan 2017
SOLD
Power windows, power door locks, power steering, all working. Interior is in wonderful condition. Clock, radio, interior and exterior lights all in perfect working order. Seat belts all intact and functioning. All stock except for driver's seat cover was replaced. All weather floor mats and trunk area mat added. Dash is in perfect condition, no cracks. Added dash cover to keep it nice. All gauges, lights etc in working order. Windows, trim, locks latches and handles are all in perfect working order. Wipers have new blades.
Have original Owners Manual, bottle jack and tool kit.
My wife and I bought this Cruiser last year with the intention of driving it forever. It was my wife's daily driver, and as such I needed to know it would be safe, reliable and mechanically sound. The Cruiser was in beautiful shape when we bought it, but I knew it needed some freshening up to be a true daily driver. A few weeks after buying it I took it to renowned Land Cruiser mechanic Georg Esterer at Valley Hybrids in Stockton. Georg went over the truck with a fine tooth comb and replaced, upgraded or fixed everything he could find. All in all I spent $6,000 to bring this truck up to be a quality daily driver. Work performed is listed below. Georg and his crew had the cruiser for a few weeks and literally went through every nut and bolt on the the thing. After getting daily updates, pictures and an ever growing list of parts upgraded and replaced, I finally got the call to come pick it up. The cruiser has been driven over 5k miles since then, every day for the nearly a year, and has not had one single hiccup. Fires right up every time, runs flawlessly, runs cool, shifts smooth. Not one single issue. The steering, handling and ride quality are light years above what it was when I first bought it. Its basically riding on all brand new running gear.
Unfortunately it has come time to sell this awesome rig. With our expanding family we needed the option of third row seating, so a new 4Runner was purchased to take the place of the beloved Cruiser. I really wish I could just keep her, but I just have too many rigs
"The Bad"
I really don't think there is anything bad about this rig! i love the thing! But there are a few items worth noting, a few imperfections if you will. . .
-Paint. The 26 year old "Beige Metallic" is wearing a bit thin in spots. Mostly on the roof and hood, and has a faded patina look to it. I personally don't think it looks bad. Kinda like a dash of grey around the temples, gives her a sophisticated look
-Dings, scratches etc. She has a few. . . Nothing major or serious damage, just a handful of paint chips, dings and little dents in the bumpers. The worst of the lot is along the passenger side rear door, and is visible in the picture. The prior owner had used touch-up paint to cover the chipped paint, and its held up well. . .
So here she is, ready for the next adventure. Whether its camping, 4wheeling, trips to Tahoe for snow season, or Baja for surf, or just back and forth from work and play with you and the fam, or the dog. . . She's ready to go! Call or text to come see her. Located in Penngrove, CA. North Bay Area. About an hour north of San Francisco.
Maintenance, Upgrades and Modifications
*New suspension
Old Man Emu Deluxe Medium Duty Lift Kit (2-3" lift) http://www.cruiseroutfitters.com/sus_60series_dakar.html
2 - CS003F Front OME Emu Dakar Leaf Springs
2 - 60009 Front Nitrocharger Sport Shock Absorber
2 - CS017R A/B Rear OME Emu Dakar Leaf Springs
2 - 60032/62 Rear Nitrocharger Sport Shock Absorber
4 - SB1 OME Poly Spring Bushing Kits
1 - OMEGS2 OME Greasable Front Shackle Kit
1 - OMEGS1 OME Greasable Rear Shackle Kit
2 - OMEGP1 OME Greasable Pin Kit
1 - OMESD24 OME Steering Stabilizer
8 - OMEU51/59B OME U-Bolts & Nuts
Man-A-Fre U bolt Flip Kit http://manafrelv.com/product/man-a-fre-4plus-u-bolt-flip-kits-land-cruiser-40-and-60-series/
Extended Brake lines and hoses front and rear.
Extended Sway Bar end links http://manafrelv.com/product/60-series-rear-anti-sway-bar-extended-links/
4 degree axle shims http://www.coolcruisers.com/shimsspring.html
Power steering box rebuilt. New O-rings, seals, fluid.
Knuckles fully rebuilt. With new Spindle lock kit. http://www.cruisercorps.com/front-axle-rebuild-kit-1975-1990.html?gclid=CNz2yoqbi80CFQyEaQodKEcFgA
Tie rod ends replaced http://www.jtoutfitters.com/fj60-62-tie-rod-end-kit-p-2712.html
New Wheel bearings and grease.
Heavy Duty Inner axle seals
*Brake system entirely redone. Brand new Rotors, Calipers, Pads, hard lines, fluid in front. Brand new Drums, Shoes, bolts, hard lines, fluid in rear.
*Engine Tuned up and maintained
Valves adjusted, new valve cover gasket, grommets, new PCV valve.
EFI system cleaned.
New Battery, heavy duty battery terminals, heavy duty battery cables, battery hold-downs.
Headlight system upgraded to Hella H4-H1 with heavy duty harnesses and Bussman fuse box. Harness and kit created by SLCFJ62. http://forum.ih8mud.com/threads/headlight-wire-harness-fj60-and-fj62.354712/
Absolutely one of the best upgrades I've made on this truck. The stock headlights are a joke. You can barely tell they are on unless its pitch black out. The upgraded system from SLCfj62 is light years (pun intended) better. Heavy duty wiring, relays and watertight Bussman fuse enclosure make for a rock solid power system to run the proven Hella H1/H4 lights. The best headlight upgrade out there for these trucks, and no longer available!!
ALL FLUIDS flushed and replaced. New drain plugs installed. Tranny, front and rear Differential, Transfer case. Radiator flushed with new coolant. New drain plug.
Driveline lubed, all shackles greased, tie rod ends greased.
New Spark plugs, cap and rotor.
Lower coolant return hose replaced.
Carb cooling fan sensor replaced.
Air conditioning unit upgraded to R134A. Blows Cold!
Horn button fixed.
All vacum hoses tested and in good working order.
Additional upgrades:
New rims and tires
Brand new set of 5 16x8 Stealth Custom Series F-5 wheels in Matte Jet Black w/ 3.5" backspacing. No nicks, dings scrapes, curb or rock rash. http://www.stealthcustomseries.com/products/wheels/f5/
New BF Goodrich All Terrain KO tires in Size 285/75/16 (33") No patches, plugs, tears etc. Tires have approx 5K miles on them. Spare has approx 20k.
New rear lift gate gas struts. Holds the lift gate wide open with no sagging at all!
New gas cap.
Upgraded cd player and rear speakers by prior owner.
All weather floor mats and rear trunk area mat added.
Dash cover.
