I decided to get started on my Hypermax turbo install today and naturally the first thing I try to do turns into crap. The glow plug harness needs to be removed and then reconfigured for the install. The main plug that connects the harness to the vans main wire bundle was locked up tight without much interest in coming apart. After some persuasion I got it separated but it's crumbling, which after 24 yrs of hot/cold cycles is not surprising, but it does leave me up feces creek without the necessary paddle.
Does anyone know where I can source either a compatible harness whose cost won't make me blow chunks, or a factory style pin compatible plug? Even some sort of aftermarket plug like weather pak as long as it would accept the pins already installed. I REALLY don't want to have to repin both sides of the bundle.
Shot in the foot right out the gate.
