KarmannMarco
Nice stanceworks license plate trim :smiley_drive: I used to be on there a bunch when I had my E24 635CSi
Can you provide additional pix of the rear bumper? I'm interested in having something like that made for mine. Do you know if it started out as a bumper for another car that was made to work with the montero?
So I had another ignition coil die on me yesterday... shut off as I was cruising off the highway. Luckily I had a tow strap on me, and a nice guy with a truck pulled me into a gas station to check it out. Whacked the ignition coil a couple times with the only tool I had with me... a screwdriver. Lol. Fired up and I made it home, but I'm kinda thinking maybe a borderline functioning coil could be causing my shut off's I've been experiencing.
I went ahead and ordered an OEM Mitsubishi coil, I should have known better than trusting an Autozone part. Ugh.
On a happier note, I got to do a little light offroading for work the other dayI'm a geotechnical engineer and a project I'm currently working on is a water control structure in a 70,000 acre wildlife preserve that started to fail during a tropical storm we had last year. While Florida offroading isn't terribly exciting, what made this kind of cool is that it's off-limits to public vehicle traffic, so I was the only one back there! Tons of sugar sand and beautiful forests.
The continuing saga of my failing ignition coils... kind of making me wonder if something else isn't wrong here.
Ordered a Beck Arnley Ignition Coil from Rock Auto. I've had good success with Beck Arnley stuff showing up with a Mitsubishi box inside the Beck Arnley box, so for $40 I gambled that hopefully that would happen again (since the OEM coil is $190ish). Unfortunately the box showed up with "Made in the USA" on the side of it, so I immediately knew it wasn't an OEM part.
Went ahead and installed it, truck ran great. Went to the car wash and the store for some dog food, still ran great. Pulling out of the store to head home, the truck fell on it's face and refused to accelerate. Then it barely ran. Then it finally shut off altogether... coasted to a side street and popped the Autozone coil back on (that I luckily brought with me) and it fired up and drove home perfectly. The Beck Arnley coil was very hot and appeared to have melted a little bit, the magnet was loose feeling.
Now the truck is running, but I'm worried that the autozone coil will fail again. So today I went on my lunch break to a nearby junkyard, hoping to find a Montero. They listed two Gen 2 trucks on craigslist, but that was over a month ago and this yard has a quick turnover rate. With my luck, both trucks were already gone. However I'd noticed that quite a few Chrysler and Dodge vehicles shared an ignition coil with my Montero, and after a bit of searching I found a row of three minivans that all had the correct coil. What sort of confused me was that they all had matching "Diamond" ignition coils. A Google search reveals it's a Michigan based company. (Edit, a little more Googling and I found out it's a Japanese company with a Michigan office... they appear to be OEM Subaru coils on the mid 90's Legacy as well.) Maybe Chrysler used them for their OEM coils?
Anyone have an idea why I keep killing coils? Is there something else I should be looking at here, or have I just had a run of bad luck with poor quality parts? Think this Diamond coil will be reliable, or should I just pony up and spend $200 on an OEM Mitsubishi coil? Or would a Bosch (made in Japan) coil do the trick? They run around $100... I'd really like to not worry that my truck is going to strand me, and other than this stupid coil issue, it's been rock solid reliable!
