Ninelitetrip
From the The Fit Garage
Along with a clean Oregon title and plates, this restored 1994 HZJ75 Landcruiser will be offered with the following:
$89,500
Optional Equipment:
Delivery: November - December 2021
Toyota’s fully mechanical 1HD-T Engine was sourced from an HDJ81. Completely serviced with water pump, timing belt, tensioner, seals, gaskets. Turbo replaced with a G-Turbo Grunter built to spool fast keeping EGT temperature low - critical on the Toyota diesel engines. Bottom End Bearings replaced with ACL bearings, a known factory flaw on 1HDT engines. Intake and Exhaust manifolds ceramic/powdercoated and all hoses, lines, sensors replaced with new OEM. Compression tested at 450-460 across the board.
Anything showing wear was replaced with new OEM or upgraded aftermarket. Hinges, locks, latches, handles, interior plastics, lights, electronics, etc. New seats were sourced from a new body VDJ78. Rubber floors restored with factory replacements along w/new insulation.
Lizard Skin Ceramic sound deadening and heat insulation sprayed into doors, rear cavities, floors keeps noise and heat at a minimum.
A complete game-changer for a Troopy - an Alucab Hercules conversion was installed. Nibblers are used to cut the original thin sheet metal off the truck. Prepping for installation includes sanding and coating with POR-15 rust prevention followed by bracket installation.
Battleship Troopy LHD — Fit Garage
www.thefitgarage.com
- Exterior/Interior paint acid striped and repainted “Admiralty Blue-BU101”. Rust removed, treated and repaired before primer. Rust-free frame cleaned, sealed and painted.
- 1HD-T engine installed w/H55F Transmission, transfer case serviced
- Australian G-Turbo w/3“ stainless exhaust
- Alu-Cab Hercules roof conversion, installed ($11,500 total cost)
- Factory Heat and A/C added
- Dobinson 2” Lift with all new leaf springs, shocks, grease-able shackles and pins
- Front and Rear Axles rebuilt w/new brakes, wheel bearings, trunnion bearings, races, seals, felts, etc
- Wheels + Tires of choice
- ARB Front Bumper
- ExpeditionOne 70 Series rear bumper with swing-outs
- Interior refinished to new with OEM parts including dash pad, dash trim, doorcards, handles, rubber floors + Front double-bench seat and 4x rear folding seats sourced from a 2020 Toyota VDJ78 Troop-carrier
- Double Din Car-Play headunit w/new speakers
- 100% new window runs, door seals, hardware, latches, keys, etc
- Mechanically ran through with new fluids, road tested, etc
- Truck-Lite LED headlights, OEM signals, grille, taillights etc
$89,500
Optional Equipment:
- Scheel-mann Vario F seats: 11way adjustable w/heat - $4500 installed
- Alucab Shadow Awning - $1750 installed w/brackets
- Warn or Come-up winch - $800-1500 depending on model
- Explore-Glazing Pop Out rear windows - $600 per window installed
- PDI Intercooler system- $3800 installed
