1995 E350 Quigley wont shift through gears in 4-low
gtbensley
Runs and shifts great in 4x4 high and 2wd.....in 4-low it just stays in first gear or second if I choose it on the shifter. Wont shift through the gears.
Any idea what I should look for first?
Running down the road its normal
Thanks
ujoint
Supporting Sponsor
Van doesn't know its in low range, I never recommend to be in low range & drive anyway, hold it in 1st or 2nd. If you need to go fast run it in high.
gtbensley
It used to have no problem shifting in 4-low....where would I look to fix this? I dont drive first in 4-low but like to run it on tight slow dirt roads to help control speed down hill (under 10 mph).
The indicator on the dash shows it being in 4x4......
Mitch Bears
