1997 F350 4x4 CREW & BIGFOOT CAMPER
Bigfoot on Ford
This isn't easy but after buying a new truck last September its now time for me to part with my 1997 7.3 4x4 crew cab truck. I bought this tuck in 1998 and have have always taken great care of it
1997 F350 crew cab long bed with custom aluminum flatbed.
Bought in 1998 with 8,000 miles, currently 307,750 miles
Oil regularly changed
Always added ATF in the diesel fuel
Recent rear diff change
All-Fab custom aluminum flatbed $4,900.
Tymar intake with riffraff cover
Magna flow 4” exhaust
White Rogers Industrial glow plug relay
Fumoto oil drain plug
DP 5 Stage Tuner on the fly
Pillar gauges, exhasust temp, boost, tans temp
Torklift F1000 rear hitch $600
Torklift front and rear camper tie downs
Curts 2” front receiver hitch
PMF Reverse Shackle Kit $410
PMF OBS Track Bar Bracket $75
PMF 1988-1997 F-250/350 Drop Pitman Arm $75
PMF 1988-1997 OBS Ford Adjustable Trackbar $125.00
Super Duty front springs
Summit front brake lines & sway bar links $175
Bilstein 5100 series front shocks
New Sway bar bumpers
Firestone airbags
Super Springs, Super Sway Stops
Rear
PMF Ford Fabricated Lift Blocks $155.
Rancho 9000 rear shocks
S&D new rear springs dually rated lbs
285,218 change oil & filter
292,448 change oil & filter
295,024 Rear springs, Transfer Case, Rear Diff & Coolant changed $890
295,059 New rear brake seals and brakes
298,643 New Oli & Filter
303,543 New Fuel Filter
304,501 New Brake Vacuum Pump
305,225 New CPS
Truck price $18.500
2003 Bigfoot 2500 10.6 camper
BIGFOOT CAMPER 2003 ANNIVERSARY EDITION 10.6 GREAT SHAPE WITH DRY BATH. SPENT THE FIRST 11 YEARS STORED IN A BARN. THIS CAMPER IS EXTREMELY CLEAN, I DON'T THINK YOU WILL FIND A NICER CAMPER UNLESS YOU BUY NEW. BIGFOOT CAMPERS ARE MADE IN CANADA AND ARE ONE OF THE NICEST WEATHERPROOF CAMPERS MADE. PLEASE FEEL FREE TO EMAIL ME ANY QUESTIONS,
Camper price $13,500
Happykamper
Holy snot !!! You do take care of your gear !!!! That's one very nice combination:). This won't last ! GLWS ....not that you will need any luck with this setup
SonnyApril
Will the camper slide right into the stock type bed, I have a 95 f350? Are those 19.5 wheels? If so what offset did you get and how they drive?
WonaWarrior
