FJ40driver
1997 Toyota Land Cruiser Collectors Edition - Desert Dune Pearl
I am selling my 80 as I have recently gone a different direction with our overlanding setup. It is overbuilt for what we have been using it for lately and I have my FJ40 if I want to do the harder stuff. That being said it has been a tough decision to get to the point of actually listing it as I still absolutely love driving this thing. With that being said here are some pics from our most recent trips to the OBX and our NM/CO trip, where she never skipped a beat. I won't lie and tell you she is perfect, she does have some scuffs and scrapes from being used for what she was built for, as the photos will reflect. I have however tried my best to keep up with needed maintenance and use quality parts on her.
308,XXX miles
2.5in OME Heavy lift
Slee castor correction
Slee headlight harness
315/75-16 Firestone Destination M/T2 (approx 3k miles since installed 1/21)
Factory E-lockers
CDL button
pin 7 mod
ARB front bumper
Warn M12000 winch
Hudd expo skid plate
Trailgear sliders
Homebrew rear bumper with swing out
Bowfin Cruisers roof rack
Snorkel
LED dome lights
4.88 gears
Marlin Crawler low range gears - 3.112:1
Exhaust has been rerouted above the frame
Front seats have been recovered – (L-seat.com)
Front seats are heated
Steering wheel has been recovered professionally
rear storage area with fridge slide (fridge can be included for the right deal)
YodaTEQ antenna mount
wired for CB/ham radio
Icom 208H 2m/70cm can be included
Redarc trailer brake controller
Dual batteries
200w solar charging system
Delta VS panhard relocation bracket
Steering gear rebuilt with 105 sector shaft
ported for hydro assist (ram and hoses included, not installed)
Shaky mirror fix (both DS and PS) from Solve Function
aftermarket Pioneer head unit
rear door speakers replaced
Lizard Skin sound deadening
PHH replaced with silicone hose and constant tension spring clamps
LCP front sway bar disconnect
Accessories from Wits End:
Useless cubby mount
ashtray mount
York on-board air
HD rear lower control arms with new bushings
Head gasket replaced at 185k miles as PM
Items recently replaced or serviced:
fan clutch
hood mat
belts
front axle seals and bearings
oil changed every 5k miles with Rotella T6 5w-40 synthetic
headgasket replaced at 185k miles as PM
Numerous trail spares such as:
knuckle studs
fusible links
starter contacts
fuel pump relay
starter
water pump
caliper bolts
Located just east of Nashville, TN
$22,000
308,XXX miles
Factory E-lockers
CDL button
pin 7 mod
ARB front bumper
Warn M12000 winch
Trailgear sliders
Snorkel
LED dome lights
4.88 gears
Dual batteries
Useless cubby mount
ashtray mount
York on-board air
fan clutch
hood mat
belts
knuckle studs
fusible links
starter contacts
fuel pump relay
starter
water pump
caliper bolts
$22,000
