1999 Montero sunroof size
Taylor1
I need a favor. Will someone share the overall dimensions of their 1999 Montero sunroof opening? Everyone says huge or large in the search results I've found.
I'm working abroad now and collecting parts for a trip in my Montero through the NC and VA mountains. The goal is to run an RV fan in an ABS sheet that sits over the sunroof opening overnight.
Thanks guys!
Taylor1
The obvious next iteration of the idea is an acrylic sheet instead of ABS to permit star gazing in the space on both sides on the 14x14 rv fan.
The maxxair fan is 12lbs and fantastic fan is 10lbs per Amazon. Acrylic is slightly stiffer than ABS so I'm thinking 1/8" 24 x 36" can support the fan when it's sitting on all four sides by the sunroof/opening. The sunroof drops and slides so the gap at rear side will need something. Peel and stick weather strip will keep vibration down and slow down any overnight rain. The fan flange bolts to the acrylic sheet. I may run two cross strips, gasketed bolts, and wing nuts to secure the whole thing from inside so it cant wiggle around. All will be stowed inside before moving any road travel.
plh
go with Lexan, it is considerably more durable and only slightly more expensive. Acrylic cracks pretty easily.
Taylor1
Tonight I cut down the 48"x24"x1/8" lexan to 40" and cut in a 14" square centered so the maxxair fan drops in. The 1/8" lexan alone will not support the fan, so I'll brace two sides with something.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Taylor1
Prototype is done after short but sweaty three evenings in the garage. The fan and frame could be shifted front to back 1 inch to sit on the roof past the pop up visor. Since I cut it centered the lexan edge rests right at the front roof body.
Khouji
Looks good!
Taylor1
The fan works well making warm NC and VA nights Montero camping conditions comfortable. The lowest 3 of 10 speeds moves a nice gentle breeze and is nearly silent when its right above our heads. Storage during the day is cumbersome... but the whole situation in the Montero will only get better after acting on some lessons learned during the 4 night trial run.
taunger
