Off the top of my head, I'd look at the following
-Steering rack (leaks/creaks)
-All fluids (brake, steering, oil, transmission, rear diffrential.)
-Check CV boots at all corners for cracks and leaking grease
-Hit all chassis lube points with a grease gun
-Check brake pad and disc condition
-Go and buy 4 new spark plugs, air filter/cabin filter, and fuel filter. Does it have a distributer? if it does, spring for some plug wires, cap and rotor.
-Do a function check of all light bulbs and replace as necessary
-Check wipers front and rear, and replace as necessary.
-Check your fuse panel, and make note of the type of fuses you have. Go to a parts store or junkyard and get yourself 2-3 spares of whatever you need.
-Check tire pressure of all your tires including your spare and top off as necessary.
