Did you actually read what they have? Those are used motors and they are out of stock anyway.
I can sell motors for $30 and look great as long as they are out of stock. People can say, "He's got great prices!", and they're right. I just don't have anything to sell at those prices.
Check in two months, they will still be out of stock.
I had the same thing in my old '00 Disco2 with 120k miles....
thought for sure it was a lifter but no...
thought for sure it was the flex plate but no...
thought it was a loose catalytic converter but no..
LR Dealership could not locate the loud tick
Replace your oil pan gasket since it's probably leaking.... I had a really bad tick that varied in volume based on the oil weight used. when I removed my oil pan gasket I found that my #7/8 rod bearings had excessive movement if you slid them side to side. I measured all of the rod journals on the crank and found them to be ok. So... I rolled in a new set of STD rod bearings (and new bolts) and the tick went away and is still ok 1 year later.
just my $.02 from experience
You may also have two other issues that need to be looked at - as I had a "tick" in my Range Rover classic that I thought was lifters- Turned out to be an exhaust leak combined with a bad cat.
Just may want to check.
D
The ticking is more then likely caused by slight up and down movement of the cylinder liners. Mine also does this, one day it was quiet and the next it sounds a bit like a diesel, to me this rules out gradual wear items like bearings. This thread has some good answers in it. www.landroversonly.com/forums/f40/dii-engine-knock-52572/
