2000 Ford 7.3L Motovan build (225's build cont'd)
225
Village Idiot
The alternator is right above it. I can’t tell which one is making the noise. I guess I won’t know until I pull it.
gmtech
mine did that also. try a long screw driver on the pulley you should be able to hear it.
also does it have two pulleys right next together? I think I paid around 75 bucks for the tensioner with both pulleys.
when I ended up getting the tensioner on which is pretty easy the belt was so stretched the new tensioner wouldn't hold it tight enough. so I had to get a new belt also.
gmtech
belt 2.jpgbelt 1.jpgmine had roughly 243,000 when it went. its easy you don't have to move anything. but a electric ratchet does help after you brake the bolt loose.
225
Village Idiot
Thanks for the info! My Milwaukee ratchet it at home.......
It was making a rattling / chattering sound? That's what I'm 90% sure it is.
225
Village Idiot
Thanks. Good to know. I’m sending the parts to my office so I can fix it when I get off the boat.
225
Village Idiot
Not van related, but here are a few pics from work:
One happy deckhand:
The type of boat I work on:
Loading rock barges:
My other deckhand:
Probably chemical plant stuff:
Going to Decatur Alabama:
Coffeeville Locks at sunrise:
The dam at Coffeeville:
225
Village Idiot
It’s a lifestyle, not just a job. When you have an ancient job like being a captain that people have been doing for hundreds of years, a lot of respect comes along with the position.
I know it sounds silly, but out here you’re somebody. People look up to you and admire to be you. For 6 months I took a break and did a regular 9-5. And you’re just another dude punching the clock. No one cares anything about you, or your life. Just do your job and shut up.
Out here, everyone wants to be you and you’re definitely a role model. Everyone at work LOVES my van and the crazy stuff I do. No one at work has a van or anything close. So it’s fun being a little wacky and having a soon to be 4wd van.
225
Village Idiot
For a 7.3, the bearings in the middle of each wheel are about $6/each here... likely $4 for you guys. They’re easy to change out. I changed all of mine the last time I had the belt off.
I wish I could, but I'm doing it in a parking lot 12 hours from home. Then get in it and drive home.
I'm debating doing the gear change myself or bringing it to a shop. I'm putting a TrueTrac in the rear with 4.10's before I get the transmission and T-case done. Maybe an air locker in the front.
I'll pay for the gear change if it's on the $3-500 range. If it's more than that, I'll do it myself. Still pushing to have that done by 12/1, ski season.
I'll have the axle and entire UJ kit this time off, and wheels and tires next time. I'm hoping not to have to entirely rebuild the front axle. If I don't, I can meet my deadline.
Any feedback on Vision wheels?
The 17x9, -12 offset, 4.5 backspacing are $83.17 on Amazon: https://amzn.to/2OR277h The Cragar's are $118 for the same wheel.
I'm going with the BFG AT KO2 - 285x70Rx17E (33x11.50R17)
  • Like
Reactions: WVI
Bikersmurf
I here you. I had one trip when I bought a shorter belt when the A/C compressor died on the road.
I think all I used to change the bearings was a wrench and a hammer. They’re sealed and don’t even need grease.
If you rebuild the old ones you can have a spare for next time.
  • Like
Reactions: 225
Breezy78
