Selling my 2000 Land Rover Discovery 2 with the following improvements and accessories, most done within the past three years:
183,600 miles, located in Afton, WY, let me know if you have any questions or if I can tell you anything more about it - 307-880-6621
- New Old Man Emu (ARB) coils and shocks with 2" lift
- New Goodyear Duratrac tires, tire size is 265/75/16
- Tom Woods HD front and rear drive shafts
- Refreshed brake system with new rotors, pads, brake cylinder, braided stainless brake lines for 2" lift, and fluid flush
- Problematic head gaskets were replaced 60,000 miles ago, no problems since
- New water pump, coolant flush, and low temp thermostat
- Ultraguage dash diagnostics comes with the vehicle so you can monitor engine temps
- I did the shuttlevalve bypass and it does not have the three amigos
- 2004 Discovery 2 center differential lock linkage to properly engage 4WD
- 12,000lb cable winch
- Raised air intake
- Voyager roof rack and rear ladder
- ARB front bumper
- HD TerraFirma oversized spare tire mount
- TerraFirm hubcentric wheel spacers for wider stance
- Magnaflow aftermarket exhaust
- 9" auxbeam combo spotties on the bumper tied into high beam
- 7" auxbeam combo spotties on the roof rack controlled by separate switch
- GMRS radio and Aussie style front bumper antenna
- ARB single air compressor with easy access quick connect air chuck on the rear bumper
- Dual battery setup with battery isolator and shore power plug on rear bumper
- Traction boards and mount
- Drawer fridge and awning shown in the pics are not included with the sale.
