Yes. No difference
Catch and release was no understatement 😛
I will also be swapping in a 1" bore master cylinder as well.
So, most guys with Tundras do the Tundra 231mm brake upgrade, but this one will be a little different.
I recently torn down a 4th gen 4runner IFS system. So, these are off of a 07 4th gen Sport Edition model. They will ONLY work with 17" wheels and grinding is required as well as 1.25" wheel spacers. But, the rotors are 338mm in diameter and the calipers are 13WH calipers and are also 231mm.
What ya getting it off of?
2nd gen V6 4runner
I know what I'm hunting for the next time I'm out at pick-n-pull. I assume it drops right in with no issues?
Thanks for the information, you are giving me a few weekend projects![]()
The 338mm rotors were used with 18" wheels from the factory, so unless you are using 18's (or larger) then you'll need spacers so the calipers clear the hoops. 16" wheels will not fit at all. Your 20's will be fine.
At least that's how I understand it.
I asked about the MC as well, never got a response. I guess he never did the swap, it probably wasn't needed.
Bolts in.
