2001 Suburban K2500 - Summer Camping & Winter Commuting
snowblind
RhinoRack 76"x54" Pioneer Aluminum Platform
I've been thinking about adding some sort of roof platform for a few years now. Not a cargo platform though. A photography platform.
I have two Yakima Skybox cargo boxes I have used extensively for camping and travel. The cargo boxes served me well but I always disliked the vehicle handling with loaded boxes. The Suburban has always been a bit of a lumbering beast and adding weight to the roof magnifies that. I also hate having the boxes on the roof when I'm not using them.
These days my camping trips involve a lot less people and there is no need for cargo boxes. What I do have need for is a mount for my sun awning and elevation above my surroundings for taking photographs. A lightweight but sturdy roof platform with a removable ladder is what I wanted and RhinoRack and Thule had the products.
The platform is strong and relatively lightweight. On this model there are five aluminum planks and five aluminum crossbars, mounted in a frame of four aluminum rails and four plastic corners.
There are no "off-the-shelf" RhinoRack mounting solution for the GMT800 Suburbans. There actually aren't many racks available at all but fortunately I had a bunch of Thule "square bar" roof rack gear I had collected over the years.
Here is the rough mounting. The Thule crossbar positioning is a ********** because the factory roof rails are curved front to back and made it challenging to get the platform level.
The final mounting of the platform to the Thule bars will require some metal fab. The image below shows RhinoRack mounts for Rhino HD bars. The key piece of fabrication will be creating a plate that replaces one end with holes for a u-bolt that wraps the thule bar.
That's all for now. I will provide updates when we fab up the mounts.
snowblind
Bringing this thread back to life for 2025!
I will be taking the Burb up to Canada for the summer. Before that, I need to fix a few things.
More to come...
snowblind
Factory "skidplate", LED bulbs, brake pads, oil filter, hella lights for the rack, Bilstein 5100s, HVAC controller, pass-side mirror glass, and all of the parking cables.
snowblind
A decade of salty ski resort winters rusted out the trim retaining clips for the kick panels.
I found a 2002 Suburban at the local Pick & Pull with the same trim piece in perfect condition.IMG_7307.jpg
snowblind
I replaced my HVAC control unit. Now all the lights work at night.
I added a CarPlay-enabled rearview mirror/screen/camera. I'm using this in split-screen mode with my phone navigation and a high-mounted rear-view camera.
The view from the driver's seat. From top to bottom: microphone, alarm module, GPS module, Bluetooth rear-view display, radar detector, Sony XAV-712, bass speaker controls, fog, driving, and rear light switches, and 160GB ipod classic. (Not pictured: 120GB ipod touch for audiobooks and Spotify.)
snowblind
How is the ride with the 5100’s? I’m eyeing a couple of GMT800 2500’s locally (in Utah).
Hey PNUT.
The 5100s provide what I would call the "typical Bilstein ride", slightly stiffer than stock over small bumps with increased resistance to roll and dive under braking.
Matt
snowblind
I got the final roof rack / platform mounting finished today. To recap: I adapted a Rhino Rack Pioneer platform to my old Thule crossbars.
Mounts consist of a U-shaped lower piece and a flat upper piece. The first bolt clamps "DOWN", through the lower piece, while the second bolt clamps "UP" into a captured nut on the platform.
I added a pair of Hella Floods to light up the rear. You can also see the high-mount rearview camera mounted in the center of the rack.
snowblind
New air deflector and plastic "skid" plate to replace the damaged/broken parts. The air deflector was $14 at Rock Auto. The skid plate was $13. I reused my aluminum skid plate.
snowblind
Here are a few details on my roof rack setup.
Long story short: I wanted something that would work as an elevated photo platform. The photos here show the platform combined with a tripod and an extended center column. Final height is roughly 20 feet above the ground.
Roof access via Rhino Rack ladder.
The Rhino Rack Pioneer accessories mount using channels in the platform top.
Light mounts.
