2002 Toyota 4runner-built $15000
my4boys
contents of ad
Selling my 3rd Gen 4Runner, need a more economical car for commuting. I am the 2nd owner, vehicle has a clean title. I purchased it at 82K miles; since then I had all required maintenance performed. I have all receipts for parts and maintenance performed. I even have the maintenance records from the original owner.
At 85k Miles I had the timing belt done, along with the following:
Toyota Timing belt, Idlers, Tensioner, Cam & Crank seals, Thermostat & Gasket, Serpentine Belts, Water pump (with outlet pipe & Gasket), Valve Cover Gaskets, Air Surge Tank Gaskets, Spark Plugs & Spark Plug wires, spark plug tube seals, Valve cover grommets, PCV Valve & Grommet, Radiator & Hoses, AC Condenser, Optima Yellow Top Battery, Front Pads & Rotors, Rear Drum Brake Rebuild Kit, all fluids flushed. Vehicle has minor exhaust leak, new one is in the mail and on its way to me, will be fixed before sold.
Only OEM Parts were used (I might be forgetting a few things).
At 89k Miles I Installed the following aftermarket parts (All Brand New):
Toytec Boss Lift Kit w/OME 861 Rear Coils & Diff Drop
SPC Upper Control Arms
TRD FJ Trail Team Wheels
BFG All Terrain KO2 285/75/R16 (10 Ply Sidewall) (Comes with Full Size Spare)
Addco Front and Rear Sway Bars
CBI Rear Bumper with Swing Out, Spare tire Carrier, Dual Jerry Can Holder, Hi Lift Bracket & Fold Down Camp Table
Savage Offroad Sliders With Kickout (Powdercoated & Welded On)
Rear Diff Breather/Extension Kit
Gobi Stealth Roof Rack
32" Curved LED Light Bar w/OEM Switch
Smith Overland Rear Cargo Drawer System
Blaupunkt New Jersey 220 BT Radio (Clean OEM Look)
Weather Tech Floor Mats Front & Rear
Everything has 5k Miles on it, all parts were installed professionally and properly, no corners cut, vehicle was aligned after and drives straight as an arrow.
Rooftop Tent, Trasharoo, Recovery Boards, etc. are not included but I am selling them separately.
Interior is very clean, minor stain on the rear seat, no rips tears or missing trim. Exterior is very clean as well, does have some scratches on hood from original owner. Vehicle needs nothing besides a new owner and its next oil change.
Asking $15,000. FIRM
No Trades
kmroxo
I think that an "excellent" condition Limited 4Runner from 2002 with 95,000 miles has a KBB value of $6,000. I think your drawer system takes up the back seats and limits your audience. I think your pictures highlight many things that do not come with the vehicle, especially as the use of "etc" does not exactly delineate what is or is not included with your price.
I'm not in the market, but you asked for thoughts. I think those are the issues some people will have with the price.
WonaWarrior
