Backwoods Rambler
As the title says, I'm getting an intermittent P0988 error.
When the code goes away the transmission operates perfectly, but when the CEL comes on, it goes into "limp mode" and I have to shift it between 2 and D in order to drive properly and prevent over working the transmission.
After doing a bunch of research online and reading the FSM, I decided to have a mechanic friend check it out. He informed me that there are no shorts to ground, no loss of voltage, or any other issues that he could find with the wiring or voltage signals. In fact; after he verified, then cleared the CEL, the problem didn't come back for him the entire day.
I decided to get a few repair quotes. They ended up ranging from a $900 "we think that will fix it" quote, to a $3,000 "rebuild the whole thing" quote.
That didn't sit well with me and the consensus seemed to be that the transmission WAS the problem so I decided I would just swap the entire transmission myself. I found a used one through LKQ with 30k less miles than my Jeep.
After the swap, which included all new fluid (a flush) & new filters, everything seemed fine for just over 2 weeks, which was the longest the CEL went away prior to the swap, then the code came back. Then went away and came back again twice. Like I said; it's intermittent.
I did a little more research and decided to replace TCM. After that the issue went away again, but only for a day and a half.
I can swap the PCM, but I have the 4.7L H.O. and sourcing a PCM takes a bit more time since they need to ship one from out of state.
I really don't mind doing the swap, but I just don't know if going down the wrong road, or if the PCM could really be the cause of the problem.
Could my replacement transmission have been ruined by my old TCM being bad?
What are the odds that the replacement transmission has the SAME exact error code?
I'm thinking of taking it back to my mechanic friend (not free) and telling him to keep it until the code pops up for him, then check the wiring again.
Sincerely,
Frustrated and very-close-to-broke... :REOutShootinghunter
Sincerely,
