2004 B1500 conversion van - suggestions?
Sleam
Hello team, I've had this van for a few years, travelled from NM across the West all back local roads, then up to New England, back to NM now. It's simple set-up. I stripped out the seats, built a bedframe, milk crates underneath the bed etc. Good for me, two big dogs and a cat called Stephen.
I carry air compressor, maxtrax, have all terrain tires. My question is what do you suggest considering I go out into BLM and NF land mostly. I get worried about traction on muddy tracks, a bit more clearance around the wheel wells.
bbbthreat
Ground clearance helps a lot. A selectable locker, especially since you already have onboard air, would go a long way. Having some recovery gear like a Hi-Lift jack with a recovery kit or wheel lift option will help. Look into a 10-12k winch; they seem reasonable enough these days for a decent one. And of course a shovel.
Raul
For muddy BLM trails you already got good tires. A little bit more clearance may help and something like Truckclaws once you have more fender clearance. I did my homemade version few years ago, but I have not need them yet.
luthj
Engineer In Residence
Good cables or chains are very useful on mud. Just make sure you can put them on. Airing down can make a big difference, so having tools, air compressor to do so is important in my opinion.
Smudge12
