2004 GMC 4500 4 door 4x4
Peter escamilla
DESCRIPTION BY SECTION & PARTSMarch 16,2024
Chassis – 2005 GMC 4500 6.6 Turbo Diesel Duramax, 4 door, 4WD (registered in CA as a motorhome)
Body – Knapheide 14ft walk through utility box - 10 lockable boxes
Floor to Ceiling = 6’2”
Mileage - 25K on crate motor from GMC (truck has 221,600)
EXTERIOR
- Winch – smittybilt X20 17,500lb -interchangeable from front to rear
– custom D rings coming through the front bumper
- PPE transmission cooler
- 72 Gallons Fresh Water Tank
- 8 Airhorns – 2 40gallon air tanks with 90psi air chucks with inline water separator at front & rear bumpers
- After market LED headlights
- 6 off-road LED lights with light bar on front
- Above cab roof rack with extra storage lock boxes
- Spare tire with manual crane system on overhead rack
- Security system with4 motion sensor & infrared cameras with 7in display
- Two custom ladders to access roof rack – powder coated
- WeBoost WiFi Booster with antenna
- Moon roof access door to roof rack from living area
- Above box custom roof rack 14’x6’x11”tall powder coated
- Lockable metal storage box & material bin
- Insert poles for hammock system
- Two undercarriage belly boxes 6’x2.5’x10”tall, lockable & powder coated
- 3 vintage crank windows
- 6 ton roller jack along with 20ton bottle jack
- 3 - 5gallon jerry cans for water, diesel & gasoline
- Outdoor shower with on demand heater
- Custom rear hitch step
- Custom powder coated rear bumper
- 4 traffic cone holder system
- 14ft aluminum (UHaul) hidden motorcycle ramp in rear bumper
- 6” vise mounted on bumper
FUEL SYSTEM –
- Custom 70-gallon aluminum fuel tank – powder coated withrock sliders underneath for protection
- Fass fuel system with water separator and filter
- 3/4in fuel lines
Solar System
- 2 - 340watt solar panels with custom articulating frames
- 2 – 600 lithium batteries
- Victron controls with Renogy 3000 watt inverter charger
- Champion 3500 onboard generator with remote
INTERIOR
- Entire interior insulated & sound dampened
- 2 Peterbuilt air ride seats up front & 2 electric captain’s chairs in rear (currently out of vehicle but included)
- New Alpine deck stereo with 12” subwoofer - 4”mids in each door with cross overs and amplifier
- CB/Ham radio with antennae
- AC & power driver’s side mirror
- 11 rolls of SoundSkin in entire cab floor, doors, ceiling, hood, fender wells, firewall, etc
- Nature’s Head compostable toilet (a game changer!)
- 110 electric LED Fireplace space heater with remote
- 110 v Refrigerator
- Two burner gas stove (2 horizontal 20lb propane tanks)
- Toaster oven
- Sink with faucet hot/cold with 72 gallons fresh water & 10gal gray water
- Interior cabinets & dressers through out
- Two memory foam couches pull into one double bed(7’x4’), custom fabric covers & pillows
- Custom fold down bench seat
- Custom removable table
- 12 volt overhead puck lights with remote
- Many usb & 110 outlets through out
- Diesel space heater
- Laminate flooring
- 6 in-floor cargo tie downs
DRIVETRAIN
- Duramax crate motor from GM
- PPE oversized oil pan
- Aftermarket high temp green painted block
- Oversized turbo
- All new injectors
- Motor wire harness
- Banks break tuner
- Two new truck batteries
- Allison transmission with oversized torque converter
- PPE oversized transmission pan
- Transfer case rebuilt 3 years ago
- All new aftermarket Leaf Springs and U bolts - 4 stack in front, 9 in rear – drives like a dream!
- 9” drop down hyme joint link for rear sway bar
- New front and rear breaks, rotors were good
- 2-piece military grade 20” x 11” rims with extra valve stems & O-rings
- 5 - 41” continental tires
Asking $175,000.00 U.S.
Peter 7602713784
https://photos.app.goo.gl/Atcbnyu3axbUDsZYA
WonaWarrior
