2004 Sequoia (Project Baby Panda) - Adventure and Build Page
toyotech
Operations rear fusebox. 4 awg wire was used. I will be piggybacking the terminal for future air compressor. Also got an inverter going into the drawer system.
I wanted to run as little wires on the exterior as possible. So near the battery (aftermarket circuit breaker) it runs down to the frame and back up just under the driver seat (near fuel door lever). Typical I just cut a hole in the rubber grommet but I wanted a cleaner finish. Went to the drawing board and drew up a OCD WGP (wire grommet plug) did a few versions and finally got one I like.
Fusebox will sit temporarily near the side cubby hole as I got future plans to cut it out for future projects. Than the fusebox will find it’s finally home than.
busmup808
Did you make this in Solidworks? Also what type of 3D printer did you use? I’m using Prusa and Markforged in class. Nice work
redthies
Renaissance Redneck
Suspension plans? After watching a bit of that video you posted it seems like it might be a good idea to add some clearance?
WonaWarrior
