2005 F-450 4x4 Utility Body w/ Starcraft Pine Mountain Lonestar Pop-top Camper
Pacific Northwest yetti
Expedition Medic
I just wanted to say I love the build and hope to put something together along this as well. Thanks for keeping it updated with lessons learned. Happy Travels
PNWINFERNOPRO
@PNWINFERNOPRO
Ill follow along, I haven't really felt the need for singles though. I appreciated the dualies for flats....
I am on the fence.
Duals cons: can't air down, harsh ride, and chance of getting damaging rocks jammed between duals.
Sent from my SM-N910V using Tapatalk
java
You can air down some, remember your not going to run 15 psi or less like a normal truck. Too heavy for that.
Rocks pull out easy with an old strap.
Is the ride that much better with singles?
Sent from my SM-G900T using Tapatalk
PNWINFERNOPRO
@PNWINFERNOPRO
Singles allow for much lower hwy and daily driving air pressure than the 75 PSI my 19.5 Continentals require.
Things like washboard roads and chewed-up fire roads are where you will seriously enjoy the different. Drove a recently grated dirt road in Elko, NV in 2015; thought the dash was going to vibrate out the window. Had to slow to 10 mph. Was frustrating.
java
Yeah definately allows for lower pressures. I'll try a ride in yours when your done to compare
PNWINFERNOPRO
@PNWINFERNOPRO
I received my quote today. Will be measuring wheel well clearances tomorrow.
Another plus - I am running 4.88 gearing currently. The V10 with 32s has tons of power and pulls like a beast, but the RPMs get up there at hwy speeds. 35s or 37s would be just about right for the correct rpm range.
java
Awesome, I'm serious about wanting to try yours first! I need to see that rig one of these days.
I have the same issue, I could happily drop some RPM's, I'm at almost 2k at 60.
PNWINFERNOPRO
@PNWINFERNOPRO
So, the idea of swapping to Super Singles has been put on-hold for the moment. After doing some closer measurements, my rig will need some lift to clear 35s with a 13.5 or 15.5 width. I'm not sure I want to suspension lift the truck at all. The hwy ride and stability is incredible currently; like a sports car with a pop-top camper.
I may look into a slightly larger diameter dually tire instead, to gain 2-3" in height and lower my RPMs.
Psyph
