2005 Silverado 6.0L, heading to Argentina.
mccustomize
Have any of you guys had issues with CV joints/front axles?
I broke a front CV but that was wheeling with 37" Toyos so I knew I was on borrowed time. If you are worried about them you can go RCV but factory replacements are cheap enough to carry a spare.
I put 140k on my '03, a lot of it driving rough, tight forest service/Jeep roads. Every single issue I had with my '03 was steering related. Other than that, the truck was extremely solid and reliable. If I was planning a trip like yours, I would definitely consider upgrading to the Cognito parts.
locrwln
Jack,
I'll definitely look into an aftermarket tank, I think that's a good idea. I'm a farmboy and transfer tanks are always my first thought on expanding fuel capacity..
I've read through a lot of your build, I'm always happy to see someone else out there not afraid to get one of these full-size chevy's twisted up in the dirt. They really are a great mix of comfort, capacity, reliability, and capability. With the 35's aired down to about 20lbs, the 4.88's and the locker, I really haven't found many places where it will actually fit that I can't take it..
I agree, they are way underrated. Everyone automatically assumes that the IFS is going to grenade as soon as you take it on a dirt road. I had a stock '02 F350 PSD that was never offroaded and was on stock sized tires. BJ's were toast at 75k. My Chevy was a ranch truck before I bought it and I've put 70k miles on it (140k total). I had a weird popping noise on the driver's front. I kept checking and pulling and prying on anything and everything and couldn't figure out what was making the noise. I replaced the BJ's recently. The old ones were still tight, but the noise went away, so I have to assume one wasn't happy. Mine is a worse case example with the diesel and bumper/winch combo.
Other than that, like you said, if it fits, it will go.
You should have a great adventure ahead of you.
Jack
1stDeuce
220k on a duramax that was used hard before me, zero issues. Same with 150k oilfield shop truck. All original balljoints on both trucks, and they're still tight. CV's are solid, boots in good shape.
As for durability, you can keep your Ford and your Dodge. I'm with Jack on how well the GM stuff holds up. Most of my friends put track bars, tie rods, and balljoints on their "stronger" solid axle dodges about every 50k miles, or suffer death wobble. Doesn't sound "stonger" to me, and I don't think you can get a GM truck to death wobble no matter what you do... :)
I too have heard that you won't have problems with fuel. Since you're making the bed, you could always just design in places to carry two 5 gal cans for emergency use. The 15 gallon Ford tank is my best idea yet, though I must admit, I stole it from someone here... I just plan to use a pulse style transfer pump and let it pump dry when I need the fuel. :)
legendaryandrew
I love hearing about GM IFS success stories, because I love the crap out of my 'burb. Most comfortable long distance vehicle I've owned (15 total cars/trucks). And other than a rear caliper sticking and the fuel pump, both easy fixes, it's dead reliable. Moral is, you take care of it, your truck will get you there and back.
P.S. Maybe check/replace the rear calipers, I just remembered it's kind of a common problem...if you haven't already lol
pawleyk
Running from Monday..
It's good to see I'm not the only one who loves these trucks. I've received no end of advice telling me I need a Defender, Land Cruiser, or Unimog for the trip... I say the best rig is something you won't have to fix often (sorry Land Rover or Vanagon) and can fix yourself when something does break..
I do have a good Innova OBDII scanner, and was thinking about something like aa Bulldog programmer so I can keep an eye on even more parameters as we're moving. I'm reluctant to mess with the factory drivetrains though.
Any thoughts on increasing milage with the 6.0? A lot of guys say the programmers and cold air will get you a few MPG (which is a lot when you're in the 10-12 range), but I've always felt like maybe those were more just guesses at increases to justify more toys..
shopkins
aka Glitch
Cold air intake no. Leave the factory air box alone. If anything only replace the intake tube, I believe airaid makes an intake tube that still uses the factory Air box. And tuners in my opinion are negligible when it comes to fuel economy. Best bet is to just keep the rpm below 2,000.
mccustomize
I do have a couple friends with performance shops here local, and I will say that a custom tune done right, can improve fuel economy.
My wife's truck is a perfect example, when it got switched from the stock 16s and skinny tires to factory 20s with 275/55s it lost 2 full MPG. Now with long tube headers, full exhaust, K&N cold air and a custom tune it gained back those 2 full MPG (as long as she is driving)
Honestly with the weight you are adding I would strongly consider a set of long tubes, a drop in filter (I like AEM dryflow) and a custom tune. It will get you back some of your MPGs if you drive conservatively and bring back some power for grades and passing when you need it.
Keep in mind a custom tune is all about maximizing the efficiency of the powertrain combination, sure most people do it for performance, but driven smart can increase economy too. I have both our trucks with a custom tune (03 Silverado and 04 Silverado) and that was one of the best things I did to the trucks.
shopkins
aka Glitch
I agree with the custom tune. Should have been more specific. When I said tuner I meant the plug in kind. If you actually have a shop set s custom tune it can help.
locrwln
Oh yeah, stock CV's here. My FIL and MIL both have 1/2t 800 platforms (Tahoe and pickup) and both have over 200k with the entire front ends still being original to include the CV's. Granted they have seen mostly highway use, but I think that speaks to how well they can hold up.
Jack
Bushcoat
one trail at a time
I've never broken a 3/4 ton gm CV shaft, broken half a dozen half ton cv's though. I did manage a front driveshaft u joint in my duramax.
Last set of CV axles I bought for my 98 2500 were $43 each aftermarket from rock auto (new, not rebuild, and no core charge at all). At that price carrying a spare or two is easy.
PGW
Seems like the most common occurrences of 8 lug CV's breaking are from either doing boosted launches with a hopped up Duramax or improper spacing with a lift. If a lift kicks the WMS out and doesn't correct the CV spacing, the inner tripod joint will bind or come out of the cup too much and explode.
WonaWarrior
